sandip452 Posted October 25, 2021 Share Posted October 25, 2021 Hello all, I am facing one issue and need help from expert. I have elbow and wants to apply covers over it. By using Sweep I applied covers overs it. To generate Surface i used "Unwrap" command and its worked perfectly. my plan is that to generate DXF file of cover surface and send to CNC for surface cutting. But CNC not able to cut the material by using DXF file because surface generated has spline not segments. So can anyone help me how to generate DXF file which can be used for CNC machine? or how to convert spline to DXF? If same issue already discussed here then please provide link here. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
