Modify wall LISP to draw multipoint wall
xlxevilxlx
Did you look at MLINE its draws multi lines like you want can be various offsets, different linetype and layer. Ends capped or not.
If you want more than just a multi line wall then Autocad Architecture or need a add on as I suggested. The add on I have draws walls, windows, doors, roofs,eelvations plus much more but it is metric.
2 hours ago, BIGAL said:
It may be because I am in AUS but where is the Free option ? I could only find the Collection option.
Yah aus gets dicked over with software. ony $1775 here. wonder if you could save money buy buying it with vpn enabled.  still about $500 aus difference.
Edited by mhupp
