Allan B. Posted January 21 Author Share Posted January 21 Thank you for taking interest, The applications I have written are to long sent out. I will take today and check for spelling errors . I know that if I call up each items in the list separately without the foreach function, I have no problem. I am now also trying a different approach (foreach pt list (command pt "copy" etc,etc )) I will get back tomorrow. Allan Quote Link to comment Share on other sites More sharing options...
Steven P Posted January 21 Share Posted January 21 You could always try a while loop and a counter - I tend to go that way by default but that's just me. Added some 'princ' to tell you how it is going on as an example below.. overkill but sometimes seeing it all written out helps (princ "\nMy List: ") (princ list) ;;Gives you the full list so you can see it (setq acount 0) (while (< acount (length list)) (setq pt (nth acount list)) (princ "\n - count: ") (princ acount) ; Position in list (princ " : pt: " ; (princ pt) ; point (command "copy" pt "" basept despt) (princ "COPY OK") ; Copied OK (setq acount (+ acount 1)) ) ; end while (princ "All Copied") If it struggles at that post what the princ statements say... should be a clue in them 1 1 Quote Link to comment Share on other sites More sharing options...
Steven P Posted January 21 Share Posted January 21 (edited) You could also put in a check that your pt is of course selecting an object to copy... copy will fail if there is nothing selected to copy of course, something like this? ;;(if (setq mypoint (nentselp "Point" (list 0 0 0))) (if (setq mypoint (nentselp "Point" pt)) (progn (princ "Yes - An Object!") ;;do your copy command here ) (progn (princ "No - Not an object") ;;do something else here ) ) Another question, where are you getting the list of points from? Edited January 21 by Steven P Quote Link to comment Share on other sites More sharing options...
Allan B. Posted January 21 Author Share Posted January 21 No luck yet. I setup 2 new circle entities and put them in a list, and verified them , no confusion with any other objects or lists. Than I defined your code as a defun() . next I ran the function, the result entity name _______ entity name _______ -count : 0 pt : < entity name --------->copy ok -count : 1 pt : < entity name---------> copy oK But nothing got copied Allan Quote Link to comment Share on other sites More sharing options...
Allan B. Posted January 21 Author Share Posted January 21 Sorry Steve it did copy fine, now to to try it with my objects 1 Quote Link to comment Share on other sites More sharing options...
Steven P Posted January 22 Share Posted January 22 I was expecting "entity name" to be a point (x y z) .... Quote Link to comment Share on other sites More sharing options...
Allan B. Posted January 22 Author Share Posted January 22 As it happens I found something else, the structure of my main list has errors in its assembly, and that has been causing the copy command and foreach to fail after the 1st copy was made. I have to take a break from this for a few days, I will let you know how things turn out next week. And your code was very helpful THANK YOU Allan 1 Quote Link to comment Share on other sites More sharing options...
