how to change distance from dimension line to objects
TINDANG
Help me create a lisp to change the distance from the dimension line to the object.
or is there a way to set the default distance from the dimension line to the object for each dimstyle ?
Edited by TINDANG
1 hour ago, mhupp said:
Aww, I was looking for some good magic from you here! It would be a useful LISP to keep drawing output consistent.
I had a very quick look and it appears that the text position is controlled by DXF codes 10 and 11, you might be able to work something out with them and some maths maybe, though I haven't got chance today to see what you can do
  • Funny 1
Try this.
Certainly not completely as it should be, but it's a start.
So ... DXF 13 and 14 are the points to be measured.
I measure the midppoint between those points, then DXF 10 and 11 are set 30 units (the user sets this) from that midpoint, perpendicular to the line 13 - 14.
So for the moment it's for aligned dimentions, it won't work in all conditions.
Command DFD
(defun deg2rad (ang / )
  (/ (* PI ang) 180.0)
(defun rad2deg ( ang / )
  (/ (* 180.0 ang) PI)
;; midpoint of 2 given points
(defun mid ( pt1 pt2 / )
  (mapcar '(lambda (x y) (+ (* 0.5 x) (* 0.5 y)))
  pt1
  pt2
(defun c:dfd ( / dist sel ent al ar ang1 ang2 mp tp txp)
  (princ "\nDistance DIM: ")
  (setq dist (getreal))
  (while (setq sel (entsel "\nSelect DIM: "))
	  (setq ent (car sel ))
	  (setq txp (cdr (assoc 10 (entget ent))))
	  (setq al (cdr (assoc 13 (entget ent))))
	  (setq ar (cdr (assoc 14 (entget ent))))
	  (setq ang1 (angle al ar))
	  (setq mp (mid al ar))
	  (setq ang2 (angle mp txp))
	  (if (< ang1 ang2)
		(setq tp (polar mp (+ ang1 (deg2rad 90.0)) dist))
		(setq tp (polar mp (- ang1 (deg2rad 90.0)) dist))
	  (entmod (subst (cons 10 tp) (assoc 10 (entget ent)) (entget ent) ))
	  (entmod (subst (cons 11 tp) (assoc 11 (entget ent)) (entget ent) ))
Edited by Emmanuel Delay
@Emmanuel Delay your code places the dimension on the opposite side of the line when ar is to the left of al and the aligned dimension goes from left to right.
Here's a before and after shot.
I avoid using angles although sometimes it is easier.  Here's a modified version of your code using vectors.
  pt1
  pt2
;;;  Calculate unit vector of vector a
(defun uvec
  (a / d)
  (setq	d (distance '(0 0 0) a)
	a (mapcar '/ a (list d d d))
; Compute the dot product of 2 vectors a and b
(defun dot ( a b / dd)
  (setq dd (mapcar '* a b))
  (setq dd (+ (nth 0 dd) (nth 1 dd) (nth 2 dd)))
)					;end of dot
(defun c:test2 ( / sel ent txp al ar mp uALR s txpp uvt tp )
;;;	  (setq ang1 (angle al ar))
;;;	  (setq mp (mid al ar))
;;;	  (setq ang2 (angle mp txp))
;;;	  (if (< ang1 ang2)
;;;		(setq tp (polar mp (+ ang1 (deg2rad 90.0)) dist))
;;;		(setq tp (polar mp (- ang1 (deg2rad 90.0)) dist))
(setq mp (mapcar '/
		 (mapcar '+ al ar)
		 '(2. 2. 2.)
; uALR = unit vector from al to ar
(setq uALR (uvec (mapcar '- ar al)))
(setq s (dot uALR (mapcar '- txp al)))
; txpp = projection of txp onto the line
(setq txpp
       (mapcar '+ al (mapcar '* uALR (list s s s)))
(setq uvt (uvec (mapcar '- txp txpp)))
(setq tp (mapcar '+ mp (mapcar '* uvt (list dist dist dist))))
(entmod
  (subst (cons 10 tp) (assoc 10 (entget ent)) (entget ent))
(entmod
  (subst (cons 11 tp) (assoc 11 (entget ent)) (entget ent))
  • Like 4
Please give it a test , maybe some defun is miss, it only work for "AcDbAlignedDimension"
Feel free to add error handling or what else ......
;; Design by Gabo CALOS DE VIT from CORDOBA ARGENTINA
;;;    Copyleft 1995-2022 by Gabriel Calos De Vit ; DEVITG@GMAIL.COM
; DISCLAIMER:  Gabriel Calos De Vit Disclaims any and all liability for any damages
; arising out of the use or operation, or inability to use the software.
; FURTHERMORE, User agrees to hold Gabriel Calos De Vit harmless from such claims.
; Gabriel Calos De Vit makes no warranty, either expressed or implied, as to the
; fitness of this product for a particular purpose.  All materials are
; to be considered ‘as-is’, and use of this software should be
; considered as AT YOUR OWN RISK.
(DEFUN &-TEXT/STR-PT-HEI  (STR PT HEIG) ;_ 01
  (IF (= (TYPE PT) 'LIST)
    (SETQ P1 (VLAX-3D-POINT PT))
    (SETQ P1 PT)
  (VLA-ADDTEXT MODEL STR P1 HEIG)
(DEFUN G-MIDPOINT/P1-P2  (P1 P2) ;_01
  (MAPCAR '* '(0.5 0.5 0.5) (MAPCAR '+ P1 P2))
(DEFUN VAR->LST  (VARIANT#) ;_01
  (VLAX-SAFEARRAY->LIST (VLAX-VARIANT-VALUE VARIANT#))
;;;arrange-dim-text-position
;;;https://www.cadtutor.net/forum/topic/74346-how-to-change-distance-from-dimension-line-to-objects/
(defun arrange-dim-text-position (/
                                   ACAD-OBJ acRed ADOC DESIRED-DIST DIM-ENT-SS DIM-OBJ-SS
                                   EXTLINE1POINT-VAR EXTLINE1POINT-XYZ EXTLINE2POINT-VAR
                                   EXTLINE2POINT-XYZ MID-PT1-PT2 MODEL NEW-TEXTPOSITION-XYZ NO-WAY
                                   TEXTPOSITION-ANGLE TEXTPOSITION-OBJ TEXTPOSITION-VAR
                                   TEXTPOSITION-XYZ
                                  ) ;_  /
  (VL-LOAD-COM)
  (SETQ ACAD-OBJ (VLAX-GET-ACAD-OBJECT)) ;_ el programa ACAD
  (SETQ ADOC (VLA-GET-ACTIVEDOCUMENT ACAD-OBJ)) ;_ el DWG que esta abierto-
  (SETQ MODEL (VLA-GET-MODELSPACE ADOC))
(initget 7)
  (if (not
        (setq desired-dist (getreal "distance from side"))
      ) ;_  not
    (setq desired-dist 15.0)
  ) ;_  if
  (setq dim-ent-ss (ssget "_X" '((0 . "dim*"))))
  (setq dim-obj-ss (VLA-GET-ACTIVESELECTIONSET adoc))
;;;  (setq DIM-OBJ (vla-Item dim-obj-ss 0))
  (vlax-for
         dim-obj dim-obj-ss
    (if(= (vla-get-ObjectName dim-obj) "AcDbAlignedDimension")
    (setq ExtLine1Point-var (VLA-GET-ExtLine1Point dim-obj))
    (setq ExtLine1Point-xyz (VAR->LST ExtLine1Point-var))
    (setq ExtLine2Point-var (VLA-GET-ExtLine2Point dim-obj))
    (setq ExtLine2Point-xyz (VAR->LST ExtLine2Point-var))
    (setq mid-pt1-pt2 (G-MIDPOINT/P1-P2 ExtLine2Point-xyz ExtLine1Point-xyz))
    (setq TextPosition-var (vla-get-TextPosition dim-obj))
    (setq TextPosition-xyz (VAR->LST TextPosition-var))
    (setq TextPosition-angle (angle mid-pt1-pt2 TextPosition-xyz))
    (setq new-TextPosition-xyz (polar mid-pt1-pt2 TextPosition-angle desired-dist))
    (vla-put-TextPosition dim-obj (VLAX-3D-POINT new-TextPosition-xyz))
    );end progn
     (progn ;for no way to move
        (setq TextPosition-obj (vla-get-TextPosition dim-obj))
       (setq no-way ( &-TEXT/STR-PT-HEI "NO-way " TextPosition-obj (* 2 (vla-get-TextHeight dim-obj))))
        (vla-put-color no-way acred  )
);end prog for no way to move
    );end if
  ) ;_  vlax-for
) ;end defun
(defun c:arr-dim ()
(arrange-dim-text-position)
;;;;;;;|«Visual LISP© Format Options»
;;;(200 2 1 0 nil "end of " 100 20 2 2 nil nil T nil T)
;;;;*** DO NOT add text below the comment! ***|;
arrange dim text position cadtutor.lsp arrange dim texts.dwg
9 hours ago, TINDANG said:
@lrm, thanks, your code worked great. But in case of sizes with different length extension lines doesn't work. Can you help me?
I did the lisp as the  the image post.
I have as My personal rule , to work on the ORIGINAL image or sample.dwg , and never make any GUESS, neither ask to an ORACLE what the OP what he could done or will do .
@devitg
Quote
It looks like you did guess about the direction of the line segment and the sequence of the dimensioned vertices.  E.g.,  reverse the direction  of the polyline in your test drawing "arrange dim tests.dwg".  It is best to to minimize guesses about an OP's post but I have found many are in need of some interpretation.
@Irm , at this case I broke my own rule , a made a dwg from trash.
About how to know what dimension kind  is I use the
(VLAX-DUMP-OBJECT dim-obj t)
Because  Enget give 4 different  DXF 100 code for the same dim .
Quote
("AcDbEntity" "AcDbDimension" "AcDbAlignedDimension" "AcDbRotatedDimension")
but the DUMP
Quote
give only one
Quote
 ObjectName (RO) = "AcDbRotatedDimension"
  • 3 weeks later...
  pt1
  pt2
(defun uvec
  (a / d)
)					;end of dot
(setq mp (mapcar '/
		 (mapcar '+ al ar)
		 '(2. 2. 2.)
(setq txpp
(entmod
(entmod
thanks for your great code, it's helpful for me.
I often use this routine, after Dimensioning Multiple Segments of a Polyline Lisp (DPI DPO).
so, this is just little bit minor change of rlm's code, edit entsel to ssget
for do this routine to multiple objects in one procedure
(defun c:test2 ( / sel ent txp al ar mp uALR s txpp uvt tp exss exssent exssl exssindex)
  pt1
  pt2
(defun uvec
  (a / d)
)					;end of dot
  (princ "\nSelect DIM: ")                                    ;edited line
(setq exss (ssget '((0 . "*dim*"))))                           ;edited line
(setq exssl (sslength exss))                                   ;edited line
(setq exssindex 0)                                             ;edited line
(repeat exssl                                                    ;edited line
 (setq exssent (entget (ssname exss exssindex)))         ;edited line
;(while (setq sel (entsel "\nSelect DIM: "))                ;edited line
;	  (setq ent (car sel ))                               ;edited line
 (setq ent (cdr (car exssent)))                                 ;edited line
 (setq mp (mapcar '/
             (mapcar '+ al ar)
	 '(2. 2. 2.)
(setq txpp
(entmod
(entmod
;)                                           ;edited line while delted
 (setq exssindex (+ exssindex 1))    ;edited line for repeat added
