Bojan1994 Posted January 21, 2022 Share Posted January 21, 2022 How to rotate in Autocad polyline. Is there an option for automatic rotation? Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 21, 2022 Share Posted January 21, 2022 (edited) I would use the MIRROR command followed by the ROTATE command. When using the MIRROR command I would select as my OSNAP the Midpoint of the longer of the two lines. Note: When given the option in the MIRROR command to erase source objects answer "Yes". That would reverse the order of the two lines placing the blue colored line above the red colored line. I'd suggest using the same OSNAP on the blue colored line when both are rotated. Edited January 21, 2022 by ReMark Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 21, 2022 Share Posted January 21, 2022 Is it not a DRAWORDER question, it does what you wantt like move to top. 1 Quote Link to comment Share on other sites More sharing options...
jaimiLll Posted February 9, 2022 Share Posted February 9, 2022 Can you advise some instructional videos Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 9, 2022 Share Posted February 9, 2022 (edited) 2 hours ago, jaimiLll said: Can you advise some instructional videos You can find instructional videos about AutoCAD on "YouTube". Example... This is not a link. I just searched on the words "AutoCAD"+"YouTube". It's that easy. Edited February 9, 2022 by ReMark Quote Link to comment Share on other sites More sharing options...
