Is it Possible to create extension Like AutoRebar in Autolisp?
Ankur
Hello Everyone,
                  I wanted to know Is it Possible to create extension Like AutoRebar in Autolisp?  if no then how its create?
I haven't used that before however it looks like there is a lot in the AutoRebar button, you might want to specify what function you want to replicate.
I might note though that some of the answers will be Yes, but it is complex and will cost you for a complete solution - which is probably correct. You might just want some of the functions and you are more likely to get help writing a LISP to do that if there isn't so much to do.
If you let us know what the first part you want help with is I am sure we can do that
