B.N. Posted March 30, 2022 Share Posted March 30, 2022 Hello, I have plans where there are different lines (different layers) overlapping. Can it be visualized? either by offsetting the overlapping lines or something like a overlap counter? Other solutions may be provided! Drawing1.dwg Quote Link to comment Share on other sites More sharing options...
exceed Posted March 30, 2022 Share Posted March 30, 2022 how about to use basic command OVERKILL Quote Link to comment Share on other sites More sharing options...
B.N. Posted March 30, 2022 Author Share Posted March 30, 2022 10 minutes ago, exceed said: how about to use basic command OVERKILL I don't want to delete nor change the layer. I want to see the separate lines or see how much lines are overlapping Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted March 30, 2022 Share Posted March 30, 2022 Here is something you could play with (draworder versions are the ones I supposed you are looking for...) : http://www.theswamp.org/index.php?topic=57461.0 (You'll have to be logged to theswamp.org to access...) 1 Quote Link to comment Share on other sites More sharing options...
