Giovannino60 Posted April 8, 2022 Share Posted April 8, 2022 I can't calculate the area of this hatch, the square meters don't come out in the properties, what can I do? Thanks Area retino.dwg Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 9, 2022 Share Posted April 9, 2022 ---------- Hatch -------------------------------------------------- Handle: 2CF Current space: Model Layer: 0 Color: BYLAYER Linetype: ByLayer Pattern name: SOLID Pattern angle: 0 Pattern scale: 1 non-Associative Area: 249980.8149 I used list but the area will only be the white solid not The rectangs is that what you want. or (setq area (vla-get-area (vlax-ename->vla-object (car (entsel "Pick obj"))))) Quote Link to comment Share on other sites More sharing options...
Giovannino60 Posted April 9, 2022 Author Share Posted April 9, 2022 How did you get that list of data out? What command did you use? Thanks Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 11, 2022 Share Posted April 11, 2022 LIST 1 Quote Link to comment Share on other sites More sharing options...
Giovannino60 Posted April 11, 2022 Author Share Posted April 11, 2022 That list where do I have to copy it to get the area out? Thanks Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 12, 2022 Share Posted April 12, 2022 Its a text display, just use the lisp code I posted at post2, getting textscr is longwinded compared to 1 line of code. Quote Link to comment Share on other sites More sharing options...
