Problem with consistency
pttr
Hi I have a program that checks for at LOT of BLOCKS PLINES, and HATCHES and if the program gets a match it places it.
The problem is the placing works the 3rd time I use it, and I can´t understand why...
Some time the PLINES insertion is a bit off and sometimes it´s the blocks, but mostly it´s the Frame i create to place the Hatch in.
Here is a small peice of it
;;----HATCH----;;
    (if (setq blockss (ssget "_X" '( (0 . "HATCH") (8 . "B-B-U0013") (410 . "Model")))) ;Check if Hatch B-B-U0013 exist in model
	(setq co (list (car co) (- (cadr co)6)))
	(setq ip1 (list (car ip1) (- (cadr ip1)6)))
	(setq ip2 (list (car ip2) (- (cadr ip2)6)))
	(setq rip1 (list (-(car co)2) (- (cadr co)3)))
	(setq rip2 (list (+(car co)3) (+ (cadr co)2)))
	(setq hip (list (+(car co)1) (- (cadr co)2)))
  	(command "RECTANG" rip1 rip2) ; places rectangle "boundry for Hatch (frame)
  	(command "-HATCH" "LA" "B-B-U0013" "P" "S" hip "") ;Places hatch B-B-U0013but need boundrys (frame) and IP
	(command "-HATCH" "LA" "." "") ;Reset hatch command to avoid next hatch been predetermed
	(command "-MTEXT" ip1 "H" "1.6" "J" "ML" ip2 "Utrymningsväg" "")
    (if (setq blockss (ssget "_X" '( (0 . "HATCH") (8 . "B-B-A105") (410 . "Model")))) ;Check if Hatch B-B-A105 exist in model
  	(command "-HATCH" "LA" "B-B-A105" "P" "S" hip "") ;Places hatch B-B-A105 but need boundrys (frame) and IP
	(command "-MTEXT" ip1 "H" "1.6" "J" "ML" "W" "34" "Område som ej omfattas av brandprojekteringen" "")
If I use less parts of the code everything works fine.
Any ideas?
Thanks!
Where/how is co, ip1, ip2 being set? This is probably your issue.
--edit
Another way of calculating the different points.
(setq co (mapcar '+ co '(0 -6 0)))
(setq ip1 (mapcar '+ ip1 '(0 -6 0)))
(setq ip2 (mapcar '+ ip2 '(0 -6 0)))
(setq rip1 (mapcar '+ co '(-2 -3 0)))
(setq rip2 (mapcar '+ co '(3 2 0)))
(setq hip (mapcar '+ co '(1 -2 0)))
Edited by mhupp
I keep being second to answer after Mhupp..
I spent a lot of time getting things wrong, still do, one thing that sometimes happens for me is that I set a global variable after I have used it, so on the second pass it picks up the value but in the first it doesn't do anything.
For example
  (defun c:anexample ( / )
    (setq MyNextBlockName "AThing")
    (if (= MyBlockName "AThing") (princ MyBlockName) )
    (setq MyBlockName MyNextBlockName)
Run it once, nothing, run it again and it displays "AThing" int he command line
The other thing that often happens is it picks up a global variable from another unrelated LISP and tries to use that first off.
For example I often use 'acount' in loops so if LISP 1 sets acount to 10 then LIPS2 might be:
For example
(defun c:Lisp1 ( / )
  (setq acount 10)
  (while (< acount 5)
    (princ "\n")
    (princ acount)
    (setq (+ acount 1))
  (setq acount 0) ;;reset counter for next use
Welcome to world of debugging a LISP! Frustrates me when in my head it all works OK, but my fingers decide to type other things in
Oh, last thing.. spelling mistakes...
  • Like 2
Thanks! I´ll have to try all of this later, I´ll get a crack at it after the summer :)
Edited by pttr
