Set Dynamic Block Property - Origin
TemporaryCAD
I'm having issues with dynamicblocks and I'm pretty sure the issue stems from the origin being changed with every block I insert.  How do I set this property?
;; Set Dynamic Block Properties  -  Lee Mac
;; Modifies values of Dynamic Block properties using a supplied association list.
;; blk - [vla] VLA Dynamic Block Reference object
;; lst - [lst] Association list of ((<Property> . <Value>) ... )
;; Returns: nil
(defun setdynprops ( blk lst / itm )
    (setq lst (mapcar '(lambda ( x ) (cons (strcase (car x)) (cdr x))) lst))
    (foreach x (vlax-invoke blk 'getdynamicblockproperties)
        (if (setq itm (assoc (strcase (vla-get-propertyname x)) lst))
            (vla-put-value x (vlax-make-variant (cdr itm) (vlax-variant-type (vla-get-value x))))
I'm using Lee Mac's code to interface with the dynamicblocks.  Using this code, how do I set the "Origin" property?
I've tried lists, dotted pairs, safearrays, etc and nothing seems to work.
Thank you!
I'm guessing this is giving you an error?
Needs the vla-object name of the dynamic block not the entity name
(vl-load-com)
(setq blk (vlax-ename->vla-object (car (entsel "\nSelect Dynamic Block: "))))
(setdynprops blk  '((<Property> . <Value>)))
(vl-load-com)
No, I understand this.  I am currently using the code to edit dynamic block properties.  However, one property is the origin, which I believe is messing with some blocks as I have no control of it's value and it appears to be set incorrectly.
All I am looking to do is determine how to edit that origin parameter using that code.  Whatever datatype I send it returns an error:
(cons "Origin" (vlax-make-safearray vlax-vbdouble '(0 . 0)))
(cons "Origin"  '(0 . 0))
(cons "Origin" (list 0 0))
(cons "Origin" (cons 0 0))
(cons "Origin" '(0 0))
None of these inputs work.  How do I correctly use this code?
Thanks!
Wait is origin an attribute or a property of the block like the insertion point?
--edit
because blocks don't have a property named Origin. that i know of.
;; Dump all methods and properties for selected objects
(defun C:VDumpIt (/ ent)
  (while (setq ent (car (entsel "\nSelect Entity to Dump")))
    (vlax-Dump-Object (vlax-Ename->Vla-Object ent) t)
  (textscr)
Edited by mhupp
https://forums.autodesk.com/t5/dynamic-blocks-forum/dynamic-block-origin-0-0/td-p/1753466
Quote
Micahsa
in reply to: mbuonocore
‎09-06-2006 06:38 AM
The only thing I can think of is to add a base point parameter at 0,0,0 within your db, then line up everything from there. I can't think of any other reason for the block to shift positions on you aside from that.
--edit
  (textscr)
When I use Lee Mac's getdynprops function, I get the following result from the block: (("Stand" . "VisibilityState0") ("Right Arm X" . 74.0225) ("Right Arm Y" . 50.2598) ("Left Arm X" . -56.4576) ("Left Arm Y" . -17.357) ("Stand Height" . 158.5) ("Origin" 0.0 0.0))
I specified all of those except for origin.  I assume it's an intrinsic property of a dynamicblock.
EDIT: Here's LM's code for reference:
;; Get Dynamic Block Property Value  -  Lee Mac
;; Returns the value of a Dynamic Block property (if present)
;; prp - [str] Dynamic Block property name (case-insensitive)
(defun LM:getdynpropvalue ( blk prp )
    (setq prp (strcase prp))
    (vl-some '(lambda ( x ) (if (= prp (strcase (vla-get-propertyname x))) (vlax-get x 'value)))
Edited by TemporaryCAD
IDK one of the limiting factors of the version of BricsCAD I have. you can use but not create or edit Dynamic blocks. so I'm a little in the  dark on this one.
This topic is very important to me as this is holding up an entire project.  Here's an update from some troubleshooting:
(setq values (cons "Origin" '(0.0 0.0))) ;input values in an association list
(setdynprops (blk values)) ;blk is the block entity reference for the dynamicblock
Returns
; error: bad argument type: consp "Origin"
and flags this line from Lee Mac's setdynprops code:
With (car x) being underlined.
This is confusing to me as running the (cons (strcase (car x)) (cdr x)) code outside of the lambda function works without the error.
I'd greatly appreciate some clarity on this matter.
Edit: I think I located the issue: can I create a dotted pair that references a list?  i.e. (Origin . (0.0 0.0))
Does this information hold for AutoLisp?
@TemporaryCADThat function by Lee that you are referencing accepts an association list of values. Therefore it goes as ((<property1> . <value1>) (<property2> . <value2>) .... (<property_n) . <value_n>)). If you were using setdynprops, you will need values as: (setq values (list (cons "Origin" '(0.0 0.0))))
If that still yields an error, try (setq values (list (cons "Origin" (vlax-3d-point 0.0 0.0))))
Edited by Jonathan Handojo
Thank you!  That got through the first layer of issues.  I had missed that the association list had to be wrapped in a list.
Now, I've encountered a different issue.  I am trying to set a point that refers to a single property name.  This is causing issues, as I am now seeing this error:
lisp value has no coercion to VARIANT with this type:  (0.0 0.0)
In this code:
For the other points I've set they've had separate x and y coord properties, but this one wants both values at once.  When I use Lee Mac's getdynprops code, it returns a list of reals.  I had hoped returning that would work, but now it is throwing the above error.
Please advise!
@TemporaryCAD Correct. So then it seems you need to convert the list input into a 3D point that is ActiveX compatible. This is done so using vlax-3D-Point. You can easily do it using (vlax-3D-point 0.0 0.0). Or if you are passing the list that's returned by getdynprops, you may choose to convert it like this:
(setdynprops <block_1>
    (mapcar
        '(lambda (x / v)
             (cons (car x)
                   (if (and (listp (setq v (cdr x))) (vl-every 'numberp v))
                       (vlax-3d-point v)
                       v
        (getdynprops <block_2>)
  • Like 2
(setdynprops
    (mapcar
        '(lambda (x / v)
             (cons (car x)
                       (vlax-3d-point v)
                       v
        (getdynprops <your_block>)
Thank you for the excellent advice.
I wrote a quick function to keep the origin at (0,0):
(defun resetorigin (blk)
    (if (eq (strcase (vla-get-propertyname x)) "ORIGIN")
      (vla-put-value x (vlax-3d-point 0.0 0.0))
However,  I am getting an "Automation Error. Invalid input" - I've never encountered this before.  Do you have any idea what might be causing this?
Hmm... that's a first for me as well. Do you have the block in question? Maybe might be worth seeing what's wrong with it and if I can debug some issues. Perhaps others might have heard of this issue.
Unfortunately I cannot share the blocks I am working with, but you should be able to use any dynamicblock for testing (I believe they all share an origin property).
I am wondering if I am selecting blocks incorrectly: I am using (resetorigin(vlax-ename->vla-object(car(entsel)))) to quickly check the code and it does throw an error:
(vla-get-propertyname (getdynprops(vlax-ename->vla-object(car(entsel)))))
Select object: ; error: bad argument type: VLA-OBJECT (("Distance1" . 15.0497) ("Origin" 0.0 10.0))
However, the code in question works differently as it uses entlast to select the inserted entity, so I'm not certain it ends up mattering.
On 8/8/2022 at 7:44 PM, BIGAL said:
"I believe they all share an origin property"
Could not find this in blocks I looked at. Maybe deeper somewhere not shown.
Interesting.  Maybe some setting, perhaps at a organization level, is generating the origin parameter.  I believe it is causing issues by altering other parameters when it is inadvertently changed.
I've attached a simple dynamic square with two parameters, including the mysterious origin.
See above for the code I am using to attempt to edit the origin.
I really appreciate all the help - if this is the root cause of my issues it will resolve a multiple week roadblock.
27 minutes ago, ronjonp said:
Take a look:
Thank you for the reply.
First, are you saying the "origin" property is read only?  Would it be possible to toggle that with a :vlax-false in code, or is that editable in the block editor?
Second, I am using VScode as that will be the future platform for autolisp.  Is there a way to see information like that with on that platform?
AFAIK it cannot be changed.
As for how to get that info in VSCODE, I'd have to defer to someone else as I've not moved into the 'future' yet :).
Edited by ronjonp
As Ron has correctly indicated, the Dynamic Block Property objects with property name 'Origin' are always read-only and cannot (and should not) be modified - such properties typically accompany other dynamic property objects corresponding to parameters whose values can be modified.
The ReadOnly property of a Dynamic Block Property object is itself read-only, as indicated by the property list returned by vlax-dump-object:
; IAcadDynamicBlockReferenceProperty: AutoCAD Dynamic Block Property Interface
; Property values:
;   AllowedValues (RO) = nil
;   Description (RO) = ""
;   PropertyName (RO) = "Origin"
;   ReadOnly (RO) = -1
;   show (RO) = 0
;   UnitsType (RO) = 0
;   Value = (0.0 0.0)
