Label layer w/ multileader
jonathann3891
I'm working on a lisp that will label an object's layer with a multileader and a field, but I've hit a wall.
I cannot get the field to populate.
What am I missing?
(defun C:TTT (/ ss sss)
 (and
   (setq SS (car (entsel "\nSelect item to label: ")))
   (setq SSS (tblsearch "layer" (cdr (assoc 8 (entget SS)))))
     (command "_.MLEADER")
     (while (= (logand (getvar 'cmdactive) 1) 1) (command pause)) ; this is required for multisegment mleader
     (vla-put-TextString (vlax-ename->vla-object (entlast))
       (strcat "%<\\AcObjProp Object(%<\\_ObjId "
	       (itoa (vla-get-ObjectId SS))
	       ">%).Layer>%")
     (vla-Regen (vla-get-ActiveDocument (vlax-get-acad-object)) acActiveViewport)
   ); progn
 ); and
); defun
You need to convert the entity selected 'ss' to vla-object.
(vla-get-ObjectId (vlax-ename->vla-object SS))
Besides that, you don't the tablesearch expression that assigned to variable 'sss'
  • Like 2
Thanks @Tharwat!
The last issue is this line of code doesn't appear to be working:
The field isn't updating unless I regen or select the multileader.
(defun c:ttt (/ ss)
  (vl-load-com)
	      (itoa (vla-get-ObjectId (vlax-ename->vla-object SS)))
	      ">%).Layer>%")
      );vla
    );progn
  );defun
That's due to While function and it does not stop right after the last vertice.
It would be much better to use your certain Mleader style then you know the number of vertices required to ask the user to specify in prior of setting the field value to it, otherwise  it would be much professional way to get the number of vertices that the current mleader style uses then you modify your codes and use something like repeat ( based on the number of vertices ) then finally set the text string < field > .
Unfortunately that's above my skill level
This allows you to pick two points. so you don't need the while.
(command "_.MLEADER" pause pause)
Edited by mhupp
I just rewrote the whole thing and made it much simpler and without a field.
(defun c:ll (/ ss tStr)
  (vl-load-com)
  (setvar 'Cmdecho 0)
	tStr (cdr (assoc 8 (entget SS)))
	oLayer (getvar 'clayer)
	);setq
  (if (tblsearch "layer" "c_gen_Text")
    (command "_layer" "s" "c_gen_Text" "c" "50" "" "lt" "continuous" "" "")
    (command "_layer" "m" "c_gen_Text" "c" "50" "" "lt" "continuous" "" "")
    );if
  (vl-cmdf "_.mleader" pause pause tStr)
  (setvar 'clayer olayer)
  (setvar 'Cmdecho 1)
Edited by jonathann3891
Currently it will end if nothing is selected. How do I go about looping until anything is selected?
this will loop until you don't select anything.
(defun c:ll (/ ent str)
  (setvar 'cmdecho 0)
  (setq oLayer (getvar 'clayer))
    (setvar 'clayer "c_gen_Text") ;make layer current
  )      ;if
  (while (setq ent (car (entsel "\nSelect Entity: ")))
    (setq str (cdr (assoc 8 (entget ent))))
    (vl-cmdf "_.mleader" pause pause str)
  (setvar 'cmdecho 1)
--edit
this one uses the point of entsel in mleader so you have one less click
  (setvar 'cmdecho 0)
  )      ;if
  (while (setq ent (entsel "\nSelect Entity: "))
    (setq pt (cdr ent))
    (setq str (cdr (assoc 8 (entget (car ent)))))
    (vl-cmdf "_.mleader" pt pause str)
  (setvar 'cmdecho 1)
Edited by mhupp
