Adding environment path variable in lisp
francine2013
Hello everybody,
I would like to work with a colleague via one drive and I have a lisp to redefine all block from different folders.
The problem that I have is, using One Drive, the path of my blocks is not the same for both.
Is it possible to add, in lisp, an environment variable to avoid this problem?
Part of my lisp:
(setq G:LISTDIR (list "C:\Users\username\OneDrive\.....\01_Profiles"
"C:\Users\username\OneDrive\...\02_Gaskets"
For example on my computer I would add the environment variable : username = francine2013
(strcat  (getenv "userprofile") "\\OneDrive\\.....\\01_Profiles")
--edit
in windows explorer its %USERPROFILE%
Edited by mhupp
Thank a lot
It works fine in the first lisp but in another one where I search for blocks I get an error message  : error: bad argument type: stringp (STRCAT (GETENV "userprofile") "\\OneDrive....
Part of this lisp:
(defun findblock ( dwg )
    (vl-some '(lambda ( p ) (findfile (strcat p dwg)))
(strcat (getenv "userprofile") "\\OneDrive\\....\\01_Profiles\\")
(strcat (getenv "userprofile") "\\OneDrive\\....\\02_Gaskets\\")
16 minutes ago, francine2013 said:
Thank a lot
Part of this lisp:
  '(   "" (strcat (getenv "userprofile") "\\OneDrive\\....\\01_Profiles\\")
The " quote doesn't evaluate list items like the list (AutoLISP) function does, you need to use list instead.
Lee Mac explains The Apostrophe and the Quote Function pretty well.
  • Like 2
I've found a way to make it work but it's more by luck and your guidance. Thanks again.
Part of this lisp:
       (list
in laymen terms what tombu is saying
'((strcat (getenv "userprofile") "\\OneDrive\\....\\01_Profiles\\") (strcat (getenv "userprofile") "\\OneDrive\\....\\02_Gaskets\\"))
with the ' it only outputs what is in the list
(list (strcat (getenv "userprofile") "\\OneDrive\\....\\01_Profiles\\") (strcat (getenv "userprofile") "\\OneDrive\\....\\02_Gaskets\\"))
where list runs the starcat and getenv funtions to output
C:\\Users\\username\\OneDrive\\....\\01_Profiles\\
C:\\Users\\username\\OneDrive\\....\\02_Gaskets\\
  • Like 2
7 minutes ago, francine2013 said:
Thanks
A bit complicated for my lisp notions, but I'll try 🙂
Anything after a '( is a fixed list, CAD will take it as it is, anything after (list and CAD will try to calculate this list
For example
'( 1 2 3 4 5) is a list, 1 2 3 4 5
'(1 (+ 8 9) 3 4 5) is also a list 1 (+ 8 9) 3 4 5, and will probably be an error since it thinks the + is text, and wants it as "+"
(list 1 2 3 4 5) is also a list 1 2 3 4 5
(list 1 (+ 8 9) 3 4 5 is a list 1 17 3 4 5, noting that the 8+9 has been calculated now
That's the basic difference
Remember to define any lists within your list as a list too
In your case
this list is seen as all text items, errors for example (strcat CAD wants that to be a text string "(strcat....)
Make it up as
(list
and it should work it all out. Lee Macs description is better than mine
  • Like 3
  • Agree 1
