krautfed Posted February 20, 2009 Author Share Posted February 20, 2009 :) :) :) I got it. Looking back, my problem was "each rail on different sketch" and not using setting my project geometry as construction lines (me thinks). Just like you said... I'll see if I can't get to work on my little model plane, and I will post my results. Quote Link to comment Share on other sites More sharing options...
shift1313 Posted February 20, 2009 Share Posted February 20, 2009 I think once you get those few things under your belt you will be off to the races:) Quote Link to comment Share on other sites More sharing options...
krautfed Posted February 20, 2009 Author Share Posted February 20, 2009 Until I hit "open loop" error in Sketch Doctor, then try to Close Loop and get: Access Violation - no RTTI data! ughhh Quote Link to comment Share on other sites More sharing options...
krautfed Posted February 24, 2009 Author Share Posted February 24, 2009 I still can't get this to work. I don't know if its my understanding of constraints/project geometry or what. I'm using imported DWGs, and trying to constrain via coincident. Is this even the correct direction? I've attached my latest file. It has "rail1" as the overall, then I even tried to just use half of it... which are "rail_top" and "rail_bottom". I'm so confused. loft_try2.zip Quote Link to comment Share on other sites More sharing options...
JD Mather Posted February 24, 2009 Share Posted February 24, 2009 I'm so confused. The sooner you stop trying to use AutoCAD geometry in Inventor the sooner things will start to clear up. It's not that you can't use dwg in Inventor, but that things must be done correctly. The Garbage In - Garbage Out principle applies here (GIGO). The AutoCAD data is flawed and not worth the effort it would take to clean up. Just use it as reference in creating native geometry within Inventor. Create your three profile sketches (should be a circle and two closed splines (with fewer points required)). Put construction lines in each of the three profiles where the rails will connect. Start the rail sketches and before anything else Project Geometry the construction lines from above. This will give you endpoint snaps for the rail sketches. Quote Link to comment Share on other sites More sharing options...
krautfed Posted February 24, 2009 Author Share Posted February 24, 2009 Thank you. I got it to work this time. Quote Link to comment Share on other sites More sharing options...
