Create automatic leaders by layer name
m1r
Happy new year my friends.
Can someone help me by modifying this lisp, this code inserts a leader in one selected object and return the layer name.
It would be nice this lisp could work on multiple objects at the same time, i don't mind if the leaders with the layer name are inserted on top of each, the main objective is to make a selection window and not have to pick one single object.
Many Thanks
MLabel.lsp
Just writing this quickly,
Look at ssget instead of entsel (http://lee-mac.com/ssget.html) and do a foreach loopin each item selected
Soemthing like this (not checked that I have typed it all in correct but gives you a clue where to go with this
(defun c:Mlabel (/ ent entl obj ss x)
  (setq ss (ssget)) ; gets a selection set
  (foreach x ss ;; loop for each entity in the selection set
  (cond ((not (setq ent (ssname x ss)))) ;;gets the entity name for current position in selection set
;; (cond ((not (setq ent (car (entsel "\nSelect object: ")))))
       ((setq pt (getpoint "\nSpecify first point: "))
        (setq entl (entlast))
        (vl-cmdf "_.mleader" "_non" pt "\\")
        (while (eq (logand 1 (getvar 'CMDACTIVE)) 1) (vl-cmdf ""))
        (if (not (equal entl (setq entl (entlast))))
          (vla-put-textstring
            (vlax-ename->vla-object entl)
            (vlax-get-property
              (setq obj (vlax-ename->vla-object ent))
              (if (vlax-property-available-p obj 'LayerName)
                'LayerName
                'Layer
  ); end foreach
(vl-load-com)
3 hours ago, Tharwat said:
You can not use foreach function over selection set.
You have to use ssnamex to get all the entity names
(defun c:Mlabel (/ SS ent obj)
  (vl-load-com)
  (if (setq SS (ssget))  ; gets a selection set
    (foreach ent (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
      (redraw ent 3)     ;Highlight entity that layer name will be pulled from
      (vl-cmdf "_.mleader" "_non" (vlax-curve-getclosestpointto (setq obj (vlax-ename->vla-object ent)) (getpoint "\nSpecify first point: ")) "\\")
      ;this will pick a point on the entity
      (while (eq (logand 1 (getvar 'CMDACTIVE)) 1) (vl-cmdf "")) ;wait for 2nd point for mleader
      (vla-put-textstring (vlax-ename->vla-object (entlast))
        (vlax-get-property obj 'Layer)
      (redraw ent 4) ;un-highlight entity
--Edit
Will need to add a bit more code. ill have something later tonight.
  • needed to add redraw so the current entity would be highlighted so user can pick a point closest to it
  • moves the leader point onto the entity
  • waits for 2nd point cmdactive reused from original lisp.
  • un-highlights entity so next loop the current entity will only be highlighted.
Edited by mhupp
  • Like 2
