G.G. Posted January 4 Share Posted January 4 Hello people, is it possible to create custom paper size with autolisp, i found a lot of information how to select printer, paper, but i do not see anything for creating custom paper size. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 5 Share Posted January 5 (edited) Are you using publish or just plain PLOT ? For single dwg I have used for years a lisp, actually more like 4, A1, PDF, A3 - BW, A3 Colour. Works every single time multiple layout support. Edited January 5 by BIGAL Quote Link to comment Share on other sites More sharing options...
mhupp Posted January 5 Share Posted January 5 You have to do that in the printer settings. View your system’s printers (there are several ways to get there) Control Panel > Devices and Printers (Easiest) OR Settings > Printers & Scanners Select any Printer Select Print Server Properties on the toolbar above the printers or from Related Settings at the right hand side Select the Forms tab Click “Create a New Form” checkbox Enter the custom width and height Click OK 1 Quote Link to comment Share on other sites More sharing options...
G.G. Posted January 5 Author Share Posted January 5 The whole idea i want to create lisp that create layout with custom sizes and i can do most of the things but for creating custom paper size dont have much info. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 6 Share Posted January 6 Did you ask this elsewhere given the plot sizes were for a roll plotter ? Some suggestions were made at other post. Quote Link to comment Share on other sites More sharing options...
G.G. Posted January 6 Author Share Posted January 6 @BIGALYes, yesterday i found post from 2016 for same thing, but in the end dont have clear solution. If i do someting i will post it Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 6 Share Posted January 6 Ok sounds like same question but new poster, are you using a roll plotter ? So want long plots but without the "White" space problems. I suggested make multiple sizes in say 200mm increments then you have what you want only need to do once. Quote Link to comment Share on other sites More sharing options...
