James Steele Posted May 22, 2023 Share Posted May 22, 2023 Hi, A very simple concept in AutoCAD 3D. A cylinder sits on top of a rectangular block. Make the visual style of the cylinder solid and the visual style of the rectangular block wire-frame. Keep both the cylinder and rectangular block in the one drawing. Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
nod684 Posted May 25, 2023 Share Posted May 25, 2023 (edited) On 5/22/2023 at 12:06 PM, James Steele said: Hi, A very simple concept in AutoCAD 3D. A cylinder sits on top of a rectangular block. Make the visual style of the cylinder solid and the visual style of the rectangular block wire-frame. Keep both the cylinder and rectangular block in the one drawing. Any help would be appreciated. Try applying a 90% Transparency to your rectangular block. Then use either HIDDEN or CONCEPTUAL Visual Style Edited May 26, 2023 by nod684 1 Quote Link to comment Share on other sites More sharing options...
James Steele Posted May 25, 2023 Author Share Posted May 25, 2023 That's awesome and thank you nod684. I want to be able to show an ACAD 3D assembly and have control over the visual style of the various components. Never thought of using transparency. Quote Link to comment Share on other sites More sharing options...
nod684 Posted May 26, 2023 Share Posted May 26, 2023 4 hours ago, James Steele said: That's awesome and thank you nod684. I want to be able to show an ACAD 3D assembly and have control over the visual style of the various components. Never thought of using transparency. No problem Quote Link to comment Share on other sites More sharing options...
