Pranesh Rathinam Posted May 26, 2023 Share Posted May 26, 2023 Hello guys, I am new to this forum. I need LISP for Selection of alternate lines from the selection set of lines like 1st, 3rd, 5th, .....etc lines in Autocad. I am attaching the file with my requirement. Alternate Selection of lines.dwg Please help me out with an possible lisp solution. Also, Is there a Autocad Plugin to do this? If so Please share the link Thanks in advance, Pranesh Rathinam Quote Link to comment Share on other sites More sharing options...
rlx Posted May 26, 2023 Share Posted May 26, 2023 (edited) (defun c:t1 ( / ss l mid-pt ss->el) (defun mid-pt (e / x) (setq x (entget e))(mapcar '* (mapcar '+ (cdr (assoc 10 x)) (cdr (assoc 11 x))) '(0.5 0.5 0.5))) (defun ss->el (ss / i l) (setq i 0)(repeat (sslength ss)(setq l (cons (ssname ss i) l) i (1+ i))) l) (if (setq ss (ssget (list (cons 0 "Line")))) (setq l (vl-sort (ss->el ss) '(lambda (a b) (< (cadr (mid-pt a)) (cadr (mid-pt b))))))) (setq ss (ssadd) i -2) (while (setq e (nth (setq i (+ i 2)) l))(ssadd e ss)) (command "chprop" ss "" "color" "red" "") ) load code , start with t1 or (c:t1) , select the lines with window or crossing (no problem selecting the leaders also because they are filtered out anyway so don't worry , be happy) et voila... Edited May 26, 2023 by rlx add comments on how to use 3 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 27, 2023 Share Posted May 27, 2023 If lines all have same Y midpoint, vertical lines then the sort may not get correct order maybe a sort X&Y car & cadr. (setq l (vl-sort (ss->el ss) '(lambda (a b) (cond ((< (car (mid-pt a)) (car (mid-pt b)))) ((= (car (mid-pt a)) (car (mid-pt b))) (< (cadr (mid-pt a)) (cadr (mid-pt b)))) ) ) ) ) Quote Link to comment Share on other sites More sharing options...
Pranesh Rathinam Posted June 1, 2023 Author Share Posted June 1, 2023 Thank you rlx & BIGAL for your valuable replies. Now it is possible to select alternate line using quick select after the coloring happens to red with the help of the above lisp. I have achieved my need thank you so much Also Please do help me with gaining a small clarity about the same LISP, Is this LISP can be made/modified to select lines at the end of the LISP execution(As the result out of 150 lines 75 lines alternatively at the end of the LISP execution without changing the color)? Is there any option to control which alternate lines to get selected (I mean 1st, 2nd, 3rd,...... or 2nd,4th,6th,.....) can an option can be set for this in above same LISP? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 2, 2023 Share Posted June 2, 2023 Ok good time to start to learn lisp and the way some things work. This sets 2 variables (setq ss (ssadd) i -2) so the ss is a blank selection and i is set to -2 (nth (setq i (+ i 2)) l)) this gets a item from the sorted points l, to get the 1st item in a list of points it is referenced as starting at zero 0, so if i =-2 then (setq i (+ i 2)) = 0 next will be items (nth 2 4 6 etc so if want even lines (setq ss (ssadd) i -1) this will result in (nth 1 3 5 7 etc Keep a selection of lines is done already its ss. You need to look into using IF's so you can ask a question like change color, even or odd. (while (setq e (nth (setq i (+ i 2)) l))(ssadd e ss)) (setq ans (getstring "\nChange color Y or N ")) (if (or (= ans "Y")(= ans "y")) (command "chprop" ss "" "color" "red" "") ) Quote Link to comment Share on other sites More sharing options...
