How I insert a scale?
Hi,
Software: ACAD Civil 3D 2008
Question: Is there an easy way to draw a scale in ACAD? I'm wanting to do this in paperspace. My method is just to draw a series of boxes of known dimensions, hatch the boxes (some white and some black) to have a checkered pattern, and then insert appropriate text (numbers) above the scale. The problem is that because I'm in paperspace, when I try to draw a 6' long box (for example), it comes out way too long... :?
I've tried and tried to search this in the forums, but when I type "scale" I get hundreds of scaling questions.
Thanks, HF
A search on google turned up free ones.
"scale bar" +autocad
Also, draw the scale bars in MS, using plines with a width for the boxes, then use CHSPACE to move it into PS.
Thanks. Didn't know about the chspace command.
