When I export to EPS format all the corners with radius curves are broken apart
hi there.... recently i was searching on the net for one problem that i have
with acad 2007...so i found that you've solve the problem for one member to
your forum... so pleace can you help me with the same problem... the problem
is:
I am having a problem exporting a simple 2D drawing to EPS. When I export
to EPS format all the corners with radius curves are broken apart. also
corners rearanged, nothing is as it should to be like it is in acad.... so
pleace if you can help me... thank you
p.s. i want to put that file into illustrator od corel draw so i can make complete design for my program together with other elements...
thanks again
I've heard you get better resolution files if you plot to an eps file rather than export to.
Check "help" on that procedure. Starts with the "plottermanager" command.
yeah i know but i want to combine those files with other design elements and i cannot do that in acad... that's why i want to export it in eps... but i tried to open dwg file with illustrator....it works, it's not perfect as in acad but it is okay...for now :)
Do not export the DWG file to an EPS. Import the DWG file directly into Illustrator and change the line stroke width as needed. It should work perfectly.
