rccola Posted February 24, 2009 Share Posted February 24, 2009 Hi Im looking to add a wood floor Hatch if anyone can help. Everyone keeps saying to add it to the acad.pat file. I dont know where to find the acad.file pat file let alone add anything to it. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 24, 2009 Share Posted February 24, 2009 That's where Windows Explorer comes in handy. Just search your hard drive for its location. Click on this link: http://hatchpatterns.com/hatch_pattern_install.php It contains a basic explanation for finding and editing your acad.pat file. Ignore the reference to the author's custom hatch pattern file. Quote Link to comment Share on other sites More sharing options...
rccola Posted February 24, 2009 Author Share Posted February 24, 2009 I tried searching my hardrive but nothing came up. Can anyone give me step by step instuctions on how to a Hatch pattern? Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 24, 2009 Share Posted February 24, 2009 Maybe you should look at the link I provided. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 24, 2009 Share Posted February 24, 2009 Do you actually have a wood floor hatch pattern available to you or are you planning to create one from scratch? Quote Link to comment Share on other sites More sharing options...
lpseifert Posted February 24, 2009 Share Posted February 24, 2009 Type this in at the command line (findfile "acad.pat") this will show you the location of the file. Then follow the instructions referred by ReMark. You do have the code for the pattern, don't you? Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 24, 2009 Share Posted February 24, 2009 Installing hatch patterns in acad.pat: http://www.cadopolis.com/autocad/installing-hatch-patterns-in-a-few-minutes-.shtml Quote Link to comment Share on other sites More sharing options...
rccola Posted February 24, 2009 Author Share Posted February 24, 2009 I do have the code for the wood pattern. I just dont know how to get it on my CAD. I tried typing findfile "acad.pat" in the command line and nothing happend it just says to press F1. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 24, 2009 Share Posted February 24, 2009 You have to type it exactly as it was written above - punctuation and all! I've got to go out for a smoke. If I'm not back in an hour start without me. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 25, 2009 Share Posted February 25, 2009 if you have the code for the pattern then you can either add it to acad.pat or just create your own new one. "Mypatterns.pat" The advantage in having a custom hatch pattern file is that if you send your dwg to someone it will always look for your custom pattern which you need to send also. If you edit acad.pat then the other person will only get an error message saying it can not find the pattern and its harder to work out what is missing because of using acad.pat. I think its good practice to create your own custom line and hatch patterns rather than edit the default acad ones. Also each time you update you have to go and edit the pattern files again. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 25, 2009 Share Posted February 25, 2009 "Also each time you update you have to go and edit the pattern files again." I would tend to disagree with this statement. It's simply a matter of keeping a copy of your customized file in a separate, easily recognizable folder. I call mine MyCustomAcadFiles. It includes acad.pat, acad.lin and acad.pgp just to name a few. Quote Link to comment Share on other sites More sharing options...
A1DWG Posted February 25, 2009 Share Posted February 25, 2009 I agree with ReMark, keeping all the custom files in one handy location is a good solution. Back to the OP's question, AutoCAD depending on the version has differing names for the .pat files, try searching for "*.pat" on your hard drive, it will probably find 4 or more, you probably want the ones in Documents and Settings-Profiles ... Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 25, 2009 Share Posted February 25, 2009 Since the OP's profile states he is using AutoCAD 2008 I would assume we are looking for acad.pat at this point. Using lpseifert's suggestion on my 2009 version AutoCAD I got the following: Command: (findfile "acad.pat") "C:\\Documents and Settings\\remark\\Application Data\\Autodesk\\AutoCAD 2009\\R17.2\\enu\\support\\acad.pat" Quote Link to comment Share on other sites More sharing options...
rccola Posted February 25, 2009 Author Share Posted February 25, 2009 OK so I typed in (findfile "acad.pat") and this came up 2008\\R17.1\\enu\\support\\acad.pat What now?? Quote Link to comment Share on other sites More sharing options...
A1DWG Posted February 25, 2009 Share Posted February 25, 2009 OK so I typed in (findfile "acad.pat") and this came up 2008\\R17.1\\enu\\support\\acad.pat What now?? Open the file in Notepad and add your new hatchpattern. Quote Link to comment Share on other sites More sharing options...
lpseifert Posted February 25, 2009 Share Posted February 25, 2009 type this at the command line (startapp "notepad.exe" (findfile "acad.pat")) scroll to the bottom of the file, paste/type in the code for the hatch pattern. Don't forget to save. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 25, 2009 Share Posted February 25, 2009 I see that the rescue squad has shown up. Good. I've gotta run. Quote Link to comment Share on other sites More sharing options...
rccola Posted February 25, 2009 Author Share Posted February 25, 2009 So it worked sort of I had a bogus wood pattern. Any suggestions of where to find good Wood flooring and grain hatches Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 25, 2009 Share Posted February 25, 2009 Freebies or are you willing to part with some cash? Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 25, 2009 Share Posted February 25, 2009 Here's a hint. Let your fingers do the walking and your eyes the searching with Google. Just type in the search box (exactly as shown punctuation and all): "autocad"+"hatch pattern" This is just one of hits I got: http://www.cad-design-and-drafting-services.com/free-autocad-hatch-patterns.html There are plenty more where this came from. Try it. Quote Link to comment Share on other sites More sharing options...
