kdubbie Posted February 24, 2009 Share Posted February 24, 2009 Hello, I want to thank anyone in advanced for any help they can offer. I've tried looking some of these up, but I just couldn't find an answer. I create show programs for Trade Shows, which usually includes a floor plan of where it's being held, with all the booth names, booth #s, etc. I receive a floor plan from someone as an AutoCad file and I need to bring it into Illustrator so that I can change the entire look of it. Bascially make it more "cartoony" (for a lack of better words) white booths with black strokes, a condensed font for the booth #s and extra condensed font for the booth names. What I am finding VERY frustrating is when I bring the .dwg file into Illustrator, each booth name that takes up two lines, gets chopped up, so, say for example: in AutoCad JOE SHMOE ENTERPRISES is all in one text box, but when I bring it into Illustrator, JOE SHMOE is one text box and Enterprises is in another. Am I importing it wrong? Why do my text boxes keep getting chopped up? Does anyone know how to prevent this? Of course, I would very much prefer to format every booth name at one time in AutoCad, does anyone know how I can select all Mtext on one layer, so that I may format everything at once? Do I have to change the color of the layer to change the color of the text? How do I change the Units from FEET/INCHES to points like in normal programs... Does MText/polymorph lines make a difference for commercial CMYK printing? If it does, how can I convert it to Mtext to text and polymorph lines to normal lines? Sorry for the long post and again, very much appreciate any assistance, Kdubbie Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 24, 2009 Share Posted February 24, 2009 Just how do you bring an AutoCAD drawing into Illustrator? What file types are acceptable? Quote Link to comment Share on other sites More sharing options...
kdubbie Posted February 25, 2009 Author Share Posted February 25, 2009 I am using the actual .dwg file. I open illustrator, then click open and search for the .dwg file. Once I click open, I get a dialog box that asks how I want to scale the floor plan. I Hit ok, and it opens....It opens just as I see it in AutoCad, but the text is chopped up. I tried exporting as an EPS file, but that completely ruins the text once I open it in Illustrator, looks very bad Quote Link to comment Share on other sites More sharing options...
skipsophrenic Posted February 25, 2009 Share Posted February 25, 2009 Have you tried saving the original drawing as a dxf and using that? Quote Link to comment Share on other sites More sharing options...
f700es Posted February 25, 2009 Share Posted February 25, 2009 You are seeing single line text created with the dtext command and you want to see multi-line text created with the mtext command. I just tried this and this seems to be the reason. Good luck Quote Link to comment Share on other sites More sharing options...
tajanat Posted November 5, 2010 Share Posted November 5, 2010 Hi, @f700es! I have the same problem as @kdubbie. But I didn`t understand your answer, @f700es. What is the "dtext"? Text in my AutoCAD drawing is created with the "mtext", but when I open it in Adobe Illustrator CS3 it becomes sigle-lined. How can I keep it to be multi-lined? Thank you in advance! T Quote Link to comment Share on other sites More sharing options...
tajanat Posted November 5, 2010 Share Posted November 5, 2010 how to convert dtext back to mtext in illustrator? Quote Link to comment Share on other sites More sharing options...
tajanat Posted November 5, 2010 Share Posted November 5, 2010 Does anyone knows if this problem shows up also in Adobe Illustrator CS4 or CS5? Quote Link to comment Share on other sites More sharing options...
tajanat Posted November 5, 2010 Share Posted November 5, 2010 how to convert dtext back to mtext in illustrator? I found script for Adobe Illustrator called "join text frames" http://vectips.com/tricks/10-free-and-extremely-useful-illustrator-scripts/ It binds broken text frames perfectly. But it means that I have to jump from one group of text to another and repeat this action as many times as many groups of text I have. And sometimes it lasts to long. So I would rather to open mtext proper in Illustrator. I wonder if this problem disappears with newer versions of Illustrator! Quote Link to comment Share on other sites More sharing options...
tajanat Posted November 5, 2010 Share Posted November 5, 2010 Have you tried saving the original drawing as a dxf and using that? with dxf is the same as with dwg Quote Link to comment Share on other sites More sharing options...
Alan Sheaffer Posted February 18, 2020 Share Posted February 18, 2020 Having the same problem a decade later, has anyone actually figured this out? The text is created using MTEXT, but when imported into Illustrator, the object becomes a group of single line type instead of a multiline type. Nothing in Autocad to Illustrator preserves a multiline text object? Quote Link to comment Share on other sites More sharing options...
f700es Posted February 18, 2020 Share Posted February 18, 2020 Are you using a truetype font in ACAD? Quote Link to comment Share on other sites More sharing options...
