Organic Posted February 26, 2009 Posted February 26, 2009 I have a DASHED line (linetype dashed) at linetype scale 1000 in model sapce. it shows up fine and the dashes are correct. In my layout I have a viewport, scaled at 1/200. The line appears, althoguh without the dashes/spaces in it. How do I carry over the line scale so it works like i nmodel space, or what calculation do I use to work out the new scale (in my viewport)? Quote
uddfl Posted February 26, 2009 Posted February 26, 2009 You can set PSLTSCALE to 0; that should work. Quote
lpseifert Posted February 26, 2009 Posted February 26, 2009 Msltscale=1 Ltscale=1 (or your preference) Psltscale=1 (needs to be set in each layout) Quote
Organic Posted February 26, 2009 Author Posted February 26, 2009 I messed around with that command. Was already on 0 and not working. Tried on 1 as well, didn't help. Reset back to 0 now. Quote
Organic Posted February 26, 2009 Author Posted February 26, 2009 Wait, one says psltscale need to = 0, other says psltscale needs to = 1 lol. So in the viewport I divide 1000 by 200 and then enter that at the ltscale? Quote
uddfl Posted February 26, 2009 Posted February 26, 2009 PSLTSCALE = 0 does it for me... Did you REGENALL? Quote
Organic Posted February 26, 2009 Author Posted February 26, 2009 Yes I used regenall. I normally don't have problems with this, so maybe it was just thsi drawing. Quote
