Changing Values in Properties Palette
Is there a setting which can be changed so that double-clicking on a value in the Properties Palette changes it from "Yes" to "No", instead of having to open the list and click on the inverse.
In LT 2000 I'm pretty sure I could double-click to make it change.
I used to be able to dbl-clk to toggle Yes/No in 2006, no longer in 2008.
