when i start using mtext half of my screen is in space for writing
any hints to fix it
area for writing is to large :o
First off, if you just type your text hit Ok and in the end it'll be ok.
If you want to change it, then go to Format > Text Style and set up your text style to match what you actually want it to be.
call me stupid,but i cant,dont now how to fix it
my problem is
i enter command pres enter,select writing area,pres enter and it happens
entire drawing area is for writing text
not half, my mistake
I know what you mean, I get it too - most of the time, I type my text, click OK to get out of the box - find the text in question, and change it afterwards.
Otherwise - go to Format > Text Style. Set the font you wish to use, set the text height that mostly use, Click Set Current, and it should look ok.
i am so histeric
enter mtext, in uper left corner of mtext on icon right click and adjust height and widht
silly me
look into the system variable MTEXTFIXED
thanks
it was at number two, it s default is one i suppose
works
i could probable live some time with my nice solution, it was realy annoying thanks
any hints to fix it
zoom in before starting the mtext command, a quick spin of the intelliwheel and you are good.
