sparkyuk Posted March 4, 2009 Posted March 4, 2009 Hi thought i had done this correctly, but i have a prob, I needed to change the xref on this drawing, so i deleted the x-ref and then installed the new xref and all seems fine until i go to plot it then comes up with this box that says "unreconciled new layers exist in the drawing the properties of these layers should be evaluated etc etc ", now it asks if i want to see to view these layers in layer properties manager i click yes it shows a xref highlighted i right click options are to "reconcile layer" i say yes it closes, but as soon as i try to print the same message pops up again ,now if i say no to opening props manager, I can then go ahead and print and it prints fine What have I done wrong please ? Quote
NBC Posted March 4, 2009 Posted March 4, 2009 what are your system variables LAYERNOTIFY and LAYEREVAL set to ? Quote
sparkyuk Posted March 4, 2009 Author Posted March 4, 2009 NBC what are your system variables LAYERNOTIFY and LAYEREVAL set to ? LAYERNOTIFY and LAYEREVAL set to 15 & 1 Quote
NBC Posted March 4, 2009 Posted March 4, 2009 Setting either (but both is preferabe) to a value of 0 would suppress the 'warnings' you are receiving. Quote
sparkyuk Posted March 4, 2009 Author Posted March 4, 2009 thanks NBC will do, so there isnt anything wrong that i need to worry about then ? Quote
NBC Posted March 4, 2009 Posted March 4, 2009 No, I don't think there is anything wrong, based on the information you have given. Quote
tkelly Posted March 4, 2009 Posted March 4, 2009 No, I don't think there is anything wrong, based on the information you have given. Yes. What he has said is correct. There should not be any problem to your drawings! Tom Quote
tkelly Posted March 4, 2009 Posted March 4, 2009 Yes. What he has said is correct. There should not be any problem to your drawings! Tom Indovance Inc. Also, Thanks to NBS for letting me know the new layer commands. Its always good to know new things. Keep posting. Tom Quote
