is it required to make any settings before start drawing in auto cad 2009. i.e. setting of limits, setting of text & dimension styles / size etc.
Or can I start drawing straight away 1:1
If you only want the "Standard" styles, and unit settings, then yes, you can begin drawing right away. However if you find yourself setting up the same styles drawing after drawing you would be better served creating a Template with those styles included. For more information, read through the AutoCAD helpfile about Templates.
