tank11 Posted March 13, 2009 Posted March 13, 2009 Hi there, I am having this trouble with visibility of attributes attached to a block. The scenario is this; i have a CAD block symbol and it has two Attribute tags attached to it. One is changeable (attrib2) and ones a constant (attrib1). I add a visibility control to the block to control the two attributes and when they must display. Opt1. Display attribute 1 only; Opt2. Display attribute 2 only; Opt3. Don't display any attributes. Note, the symbol is always displayed throughout the 3 options. My problem is; this all works fine if the changeable attribute has no value, just leave blank. But when something is typed in, it totally ignores the visibility control set to it when Opt3 is chosen. Is this a BUGG!! PLEASE HELP!! Quote
tank11 Posted March 16, 2009 Author Posted March 16, 2009 I have attached the drawing block. sign.dwg Quote
tank11 Posted March 17, 2009 Author Posted March 17, 2009 Works!! Whoohoo!! Golden rule never copy your attributes. You must create them individually. tank Quote
