Hi,
I have just upgraded AutoCAD 2005 to AutoCAD 2007 and now my delete key doesn't work. It workd fine in other applications but not in AutoCAD.
Any ideas...?
Regards
Steve
Thanks, that's sorted out my other post as well. Good man!!!
Pickfirst=1?
WOW Tiger, answered 2 threads with one post
I'm impressed :D
But no, you can't go home :twisted:
Sometimes I get lucky! :lol:
please..can't I go home?? It's almost snowstorm here so I'm wondering if I'll make it home at all if I don't leave soon...
hehe - what's the score now Tiger/Alan? :wink:
(oops - is this thread a non-chat one? :shifty: )
If it is then I'm sorry, but
Everybody is changing Avatar? I guess now is Tiger turn right? Who's next :P
  • 1 year later...
i see this discussion was long time ago but maybe someone can find a sollution for me. i have the same problem with not working 'delete' key, but pickfirst is set to 1 and it doesn't work...
i am using autocad 2008, on xp under parallels on a mac book pro.
best,
molend
thanks for the hint fuccaro,
but unfortunatelly it doesn't work for me. i have nvidia graphic card...
i am trying get used to the E, but i will be grateful to anyone who will let me use my delete key again! :)
  • 4 weeks later...
Hey guys, new member from TX...
I've only had this "delete key" problem twice, and the PICKFIRST=1 remedy has worked both times. What I discovered recently is that if you use the MVSETUP command, (I use this command to rotate a drawing in one viewport at a time) and then immediately do an UNDO command (ctrl+z), autoCAD will automatically set the PICKFIRST variable to "0", hence the "no delete key" action. This is not a solution, i know, but this is a HUGE inconvenience to anyone who has ever experianced it, and since the only way I've ever seen it is because of the MVSETUP command, I thought it should be in this thread.
Sean S.
AutoCAD 2007
Dell PrecisionT3400
