Hi
I'm using a title block (created in a full version of Auto CAD) with Auto CAD LT 2009.
The Attributes within the title block have text sizes that I wish to alter, I can do this easily within the Full version of CAD, however I'm struggling with LT.
Once in the block edditor section, if I double click or "DDEDIT" the relevant Tag, it only allows me to "Edit Attribute Definition".
Then if I highlight the Tag and go to "Properties" and for example try editing the text height, it alters the text height of the Tag but when I close the block editor and save the changes it does not change the finished text.
Hopefully someone can help with this issue.
Cheers
Maybe the "attsync" command? (not sure LT has this)
There is no "Attsync" command on LT 09.
Any one else have any ideas?
You may have to explode the block, edit text hight and re block!
I don't use LT but this should be possible!
Regards,
DECHAL.
