bookabooka Posted April 4, 2009 Posted April 4, 2009 i know this is simple to do but i just cant figure it out- ahhhh:shock:- help!!! so heres my problem, ive got a drawing at full scale that has dozens of centerlines and now im drawing a sectional view of the object at a smaller scale(4/1) just off to the side. Im trying to set the centerlines on my sectional view at an LTSCALE of .3, but when i do, the centerlines on my object that i want to keep at full scale are also set to .3 , how can i change the LTSCALE of the centerlines on my sectional view without changing center lines on my entire drawing??? N E 1 Quote
Lee Mac Posted April 5, 2009 Posted April 5, 2009 You can do the reverse of this thread: http://www.cadtutor.net/forum/showthread.php?t=33177 Quote
nocturne00 Posted April 5, 2009 Posted April 5, 2009 quick one would be to select the line then edit the line scale under its properties, then just to a match properties to the center lines you want affected Quote
