caddie Posted April 6, 2009 Posted April 6, 2009 Is there a way once you create an elevation from an elevation symbol to refresh so it updates if you say change window size or door size? Thanks! Quote
MaxwellEdison Posted April 6, 2009 Posted April 6, 2009 If you're replacing a window you'll need to go into the generate 2d Section/Elevation dialog box and add it to the selection set. Make sure you click replace existing for the insert option. If you're simply moving or resizing a window, you should be able to use the Refresh option from the context menu (right-click once the desired section/elevation is selected). Quote
caddie Posted April 6, 2009 Author Posted April 6, 2009 Thank you! I was typing in "REGEN", thinking it would refresh the elevation too! Quote
