matt4 Posted April 8, 2009 Posted April 8, 2009 Sorry for all the questions of late! I have another problem with dimensions. I want my dimensions to be something like this 6.50 however the 3rd unit is missing even though my presicion is set correctly in the dimension style emanager. What am I missing again? Thanks Quote
NBC Posted April 8, 2009 Posted April 8, 2009 In the image you attached, see where it says Zero suppression ? Remove that tick Quote
pingati Posted April 9, 2009 Posted April 9, 2009 or you can draw dimension, and then write "t", and just write 6,50 and Quote
dbroada Posted April 9, 2009 Posted April 9, 2009 or you can draw dimension, and then write "t", and just write 6,50 and however this will NOT make you any friends Quote
pingati Posted April 9, 2009 Posted April 9, 2009 however this will NOT make you any friends apssik galva daune tu bl Quote
Tankman Posted April 9, 2009 Posted April 9, 2009 In the image you attached, see where it says Zero suppression ?Remove that tick Guess that would be on "Trailing"? Quote
