ibSteveB Posted March 15, 2025 Posted March 15, 2025 I draw polylines that have circle segments for smoothing inside corners and such. I want to extract the polyline data from the DXF. I can find the polyline in the DXF and extract the start and end points of the various "VERTEX" items. The circle segments have an identifier " 42 " that clues me in that the current segment is a circle segment. But I am only finding the start point and end point for the circle segment. How can I find the center point for each circle segment listed in the polyline data? Attached are a simple polyline and CSV I extracted from the DXF. CircleSegPolyLine.CSV CircleSegment-PolyLine.dxf Quote
Steven P Posted March 17, 2025 Posted March 17, 2025 The entity definition - for example, Polyline, tries to be as efficient as it can be - uses the least dotted pair identifiers as possible... and so a smaller file size, stuff like that. That means for polylines, code '42' identifies the bulge of a segment, 0 being flat (no curve) and is a result of the arcs centre point, radius and angle. Afra Lisp gives a better description than I can here: https://www.afralisp.net/archive/lisp/Bulges1.htm Lee Mac gives some LISPs here also: https://lee-mac.com/bulgeconversion.html Quote
GLAVCVS Posted March 17, 2025 Posted March 17, 2025 Hi Try this (defun dameCentroRadio (pt1 pt2 asoc42 / dst alfa radio h angPerpn centro) (setq dst (distance pt1 pt2) alfa (* 4 (atan asoc42)) ; Ángulo del arco radio (/ dst (* 2 (sin (/ alfa 2)))) ; Radio del arco h (sqrt (- (* radio radio) (* (/ dst 2) (/ dst 2)))) ; Distancia del centro al punto medio angPerpn (+ (angle pt1 pt2) (* (/ pi 2) (if (> asoc42 0) 1 -1 ) ) ) ; Ángulo perpendicular centro (list (+ (/ (+ (car pt1) (car pt2)) 2) (* h (cos angPerpn))) (+ (/ (+ (cadr pt1) (cadr pt2)) 2) (* h (sin angPerpn))) ) ) (list centro radio) ) Quote
GLAVCVS Posted March 17, 2025 Posted March 17, 2025 (edited) 2 hours ago, GLAVCVS said: Hi Try this (defun dameCentroRadio (pt1 pt2 asoc42 / dst alfa radio h angPerpn centro) (setq dst (distance pt1 pt2) alfa (* 4 (atan asoc42)) ; Ángulo del arco radio (/ dst (* 2 (sin (/ alfa 2)))) ; Radio del arco h (sqrt (- (* radio radio) (* (/ dst 2) (/ dst 2)))) ; Distancia del centro al punto medio angPerpn (+ (angle pt1 pt2) (* (/ pi 2) (if (> asoc42 0) 1 -1 ) ) ) ; Ángulo perpendicular centro (list (+ (/ (+ (car pt1) (car pt2)) 2) (* h (cos angPerpn))) (+ (/ (+ (cadr pt1) (cadr pt2)) 2) (* h (sin angPerpn))) ) ) (list centro radio) ) This function will return a list with the center and radius. Once you have both parameters, you can get all the points you want along the arc using: (polar centro [sequence of possible angles between pt1 and pt2] radius) Edited March 17, 2025 by GLAVCVS Quote
GLAVCVS Posted March 17, 2025 Posted March 17, 2025 Of course: -pt1 is the start point of the arc -pt2 is the end point of the arc -asoc42 is the value returned by (cdr (assoc 42 ...))' on that segment Quote
