An Open-source TIN entity
Just having some fun… A custom object that does triangulation and contours. Its very fast (I think)
I’ve only tested on one drawing;
Binaries are in the release folder here  (AutoCAD 2025-2026, ZwCAD 2025-2026, GstarCAD 2026)
https://github.com/CEXT-Dan/ArxTin
Command: TINNER
Select objects: Specify opposite corner: 41769 found
Select objects:
Enter a major contour interval: 100
Enter a minor contour interval: 10
CArxTinUIApp::CArxTinUIApp_tinner Done , 0.000235 seconds
Command: LIST
Select objects:
                  CEXTDBTIN  Layer: "tin"
                   Space: Model space
                   Color: BYLAYER    Linetype: "Continuous"
                   Handle = cb4cf
Number of points:     41769
Number of triangles:  82720
Minimum elevation:    5503.992569
Maximum elevation:    7060.996567
          2D area:    37224000.000000
          3D area:    47335595.172935
  • Thanks 1
There’s a sample point drawing on github
TIN, Major and Minor and have transparency, but they are currently hard coded to TIN 50%, Minor 50%, Major %100
Oh, explode will create polylines and faces
Edited by Danielm103
Looks good,  next option would be "Add breaklines" to make the TIN take into account edges.
