naghshe Posted April 23, 2009 Posted April 23, 2009 I usually number the corners of the lot I survey clockwise 1,2,3.... Then I need to number the control points with 1001, 1002.... Normally, I let it number all points in sequence, then i go into points>edit points. Is there an easier way to do this? Thanks Quote
naghshe Posted April 24, 2009 Author Posted April 24, 2009 I mean any other way easier than what I'm doing. Is there any LISP available? Quote
naghshe Posted March 31, 2010 Author Posted March 31, 2010 Is there any lisp for numbering points? Quote
alanjt Posted March 31, 2010 Posted March 31, 2010 You can renumber a selection of points by a specified number. (ie: +100 or -516) Quote
Coosbaylumber Posted April 1, 2010 Posted April 1, 2010 The version of Softdesk I was using had an on/off automatic type of numbering system. Open up one layer and you saw all the numbers, plus those you did not want as they were sort of temporary. Overall to me was sort of annoying, as got numerous point numbers for one position. Wm. Quote
