From what I inspected... That @dexus code works well with correct implementation of djikstra... When I used his code it bumped into endless (while) loop... Here is my revision and it should work, but result is not exact... Seems that resulting polyline is rummaging between references...
Here is my revision :
; Attempt at drawing a centerline using voronoi diagram
; Voronoi diagram calculations found here: https://www.theswamp.org/index.php?topic=45085.msg503034#msg503034
(defun c:cl (/ _side ent->pts removeDuplicates minlen RemoveIDDup minpath1 triangulate getcircumcircle
               ss ent1 ent2 pl s1 s2 vor line)
  (defun _side (pline pnt / cpt end target der)
    (setq cpt (vlax-curve-getClosestPointTo pline pnt) ; https://www.theswamp.org/index.php?topic=55685.msg610429#msg610429
          end (vlax-curve-getEndParam pline)
          target (vlax-curve-getParamAtPoint pline cpt)
          der (if
                (and
                  (equal target (fix target) 1e-8)
                  (or
                    (vlax-curve-isClosed pline)
                    (and (not (equal (vlax-curve-getStartParam pline) target 1e-8)) (not (equal end target 1e-8)))
                (mapcar (function -)
                  (polar cpt (angle (list 0.0 0.0) (vlax-curve-getFirstDeriv pline (rem (+ target 1e-3) end))) 1.0)
                  (polar cpt (angle (vlax-curve-getFirstDeriv pline (rem (+ (- target 1e-3) end) end)) (list 0.0 0.0)) 1.0)
                (vlax-curve-getFirstDeriv pline target)
    (minusp (sin (- (angle cpt pnt) (angle (list 0.0 0.0) der))))
  (defun _polyline (pts)
    (entmakex
      (append
        (list
          (cons 0 "LWPOLYLINE")
          (cons 100 "AcDbEntity")
          (cons 100 "AcDbPolyline")
          (cons 90 (length pts))
          (cons 8 (getvar (quote clayer)))
          (cons 70 0)
        (mapcar (function (lambda (x) (cons 10 x))) pts)
  (defun ent->pts (ent acc / end ind step rtn)
    (setq end (vlax-curve-getEndParam ent))
    (setq ind (vlax-curve-getStartParam ent))
    (setq step (/ end (float acc)))
    (while (< ind end)
      (setq rtn (cons (vlax-curve-getPointAtParam ent ind) rtn))
      (setq ind (+ ind step))
    rtn
  (defun removeDuplicates (lst / a ll)
    (while (setq a (car lst))
      (if (vl-some (function (lambda (x) (equal x a 1e-6))) (cdr lst))
        (setq ll (cons a ll) lst (vl-remove-if (function (lambda (x) (equal x a 1e-6))) (cdr lst)))
        (setq ll (cons a ll) lst (cdr lst))
    (reverse ll)
  ; https://www.theswamp.org/index.php?topic=45092.msg578984#msg578984
  (defun minlen (LtsLine startEnd / ID1 ID2 IDEnd IDStart LtsID LtsIDFil LtsIDPnt LtsID_Edge LtsPath P1 P2 listpoint)
    (setq LtsPnt (removeDuplicates (apply (function append) LtsLine)))
    (setq LtsIDPnt (mapcar (function (lambda (x) (list (vl-position x LtsPnt) x))) LtsPnt))
    (setq LtsID (mapcar (function (lambda (x) (vl-position x LtsPnt))) LtsPnt))
    (setq IDStart (vl-position (caar startEnd) LtsPnt))
    (setq IDEnd (vl-position (caadr startEnd) LtsPnt))
    (setq LtsID_Edge (list))
    (foreach e LtsLine
      (setq ID1 (caar (vl-remove-if-not (function (lambda (x) (equal (car e) (cadr x) 1e-6))) LtsIDPnt)))
      (setq ID2 (caar (vl-remove-if-not (function (lambda (x) (equal (cadr e) (cadr x) 1e-6))) LtsIDPnt)))
      (setq LtsID_Edge (append LtsID_Edge (list (list ID1 ID2 (distance (nth ID1 LtsPnt) (nth ID2 LtsPnt))))))
    (setq LtsIDFil (RemoveIDDup LtsID_Edge))
    (setq LtsPath (minpath1 IDStart IDEnd LtsID LtsIDFil))
    (setq listpoint (mapcar (function (lambda (x) (nth (car x) LtsPnt))) LtsPath))
  (defun RemoveIDDup (l)
    (if l
      (cons (car l)
        (RemoveIDDup
          (vl-remove-if
              (or
                (and (= (car x) (car (car l)))
                     (= (cadr x) (cadr (car l)))
                (and (= (car x) (cadr (car l)))
                     (= (cadr x) (car (car l)))
            (cdr l)
  (defun minpath1 (g f nodes edges / brname clnodes closedl go new nodname old openl totdist ppath)
    (setq nodes (vl-remove g nodes))
    (setq openl (list (list g 0 nil)))
    (setq closedl nil)
    (setq go t)
    (foreach n nodes
      (setq nodes (subst (list n 0 nil) n nodes))
    (while (and go (not (= (caar closedl) f)))
      (setq nodname (caar openl))
      (setq totdist (cadar openl))
      (setq closedl (cons (car openl) closedl))
      (setq openl (cdr openl))
      (setq clnodes (mapcar (function car) closedl))
      (foreach e edges
        (setq brname nil)
        (cond
          ( (= (car e) nodname)
            (setq brname (cadr e))
          ( (= (cadr e) nodname)
            (setq brname (car e))
        (if brname
            (setq new (list brname (+ (caddr e) totdist) nodname))
            (cond
              ( (member brname clnodes) )
              ( (setq old (vl-some (function (lambda (x) (if (= brname (car x)) x))) openl))
                (if (< (cadr new) (cadr old))
                  (setq openl (subst new old openl))
              ( t (setq openl (cons new openl)) )
      (setq openl (vl-sort openl (function (lambda (a b) (< (cadr a) (cadr b))))))
      (and (null openl) (null (caar closedl)) (setq go nil))
    (setq ppath (list (car closedl)))
    (foreach n closedl
      (if (= (car n) (caddr (car ppath)))
        (setq ppath (cons n ppath))
    ppath
  ;; Triangulate                                                               ;
  ;; Structure of Program by  ElpanovEvgeniy                                   ;
  ;; 17.10.2008        ;
  ;; edit 20.05.2011                                                           ;
  ;; Program triangulate an irregular set of 3d points.                        ;
  ;; Modified and Commented by ymg                             June 2011.      ;
  ;; Modified to operate on index by ymg in                    June 2013.      ;
  ;; Contour Generation added by ymg in                        July 2013.      ;
  ;; Removed lots of code not used for centerline function     November 2025.  ;
  (defun triangulate (pl / a al b bb c cp ctr e el epos l n np npos pt r sl tl tr vl vor xmax xmin ymax ymin)
    (if pl
        (setq tl nil
              pl (vl-sort pl (function (lambda (a b) (< (car a) (car b))))) ; Sort points list on x coordinates
              bb (list (apply 'mapcar (cons 'min pl)) (apply 'mapcar (cons 'max pl)))
              ; Replaced code to get the min and max with 3d Bounding Box Routine
              ; A bit slower but clearer. zmin and zmax kept for contouring
              xmin (caar bb)
              xmax (caadr bb)
              ymin (cadar bb)
              ymax (cadadr bb)
              np (length pl) ; Number of points to insert
              cp (list (/ (+ xmin xmax) 2.0) (/ (+ ymin ymax) 2.0)) ; Midpoint of points cloud and center point of circumcircle through supertriangle.
              r (* (distance cp (list xmin ymin)) 20) ; This could still be too small in certain case. No harm if we make it bigger.
              sl (list
                      (list (+ (car cp) r) (cadr cp) 0)
                      (list (- (car cp) r) (+ (cadr cp) r) 0)
                      (list (- (car cp) r) (- (cadr cp) r) 0)
              ) ; sl list of 3 points defining the Supertriangle, I have tried initializing to an infinite triangle but it slows down calculation
              pl (append pl sl) ; Vertex of Supertriangle are appended to the Point list
              sl (list np (+ np 1) (+ np 2)) ; sl now is a list of index into point list defining the supertriangle
              al (list (list xmax cp r sl))
              ; Initialize the Active Triangle list
              ; al is a list that contains active triangles defined by 4 items:
              ;                item 0: Xmax of points in triangle.
              ;                item 1: List 2d coordinates of center of circle circumscribing triangle.
              ;                item 2: Radius of above circle.
              ;                item 3: List of 3 indexes to vertices defining the triangle
              ctr (list cp) ; added for Voronoi
              n -1 ; n is a counting index into Point List
        ; Begin insertion of points
        (repeat np
          (setq n (1+ n) ; Increment Index into Point List
                pt (nth n pl) ; Get one point from point list
                el nil) ; el list of triangles edges
          (repeat (length al) ; Loop to go through Active triangle list
            (setq tr (car al) ; Get one triangle from active triangle list.
                  al (cdr al)) ; Remove the triangle from the active list.
            (cond
              ( (< (car tr) (car pt))
                (setq tl (cons (cadddr tr) tl)
                      ctr (cons (cadr tr) ctr)) ; added for voronoi
              ; This triangle inactive. We store it's 3 vertex in tl (Final triangle list).
              ( (< (distance pt (cadr tr)) (caddr tr)) ; pt is inside the triangle.
                (setq tr (cadddr tr) ; Trim tr to vertex of triangle only.
                      a (car tr) ; Index of First point.
                      b (cadr tr) ; Index of Second point.
                      c (caddr tr)) ; Index of Third point.
                      (setq el (vl-list* (list a b) (list b c) (list c a) el)) ; ((a b) (b c) (c a) (. .) (. .).....)
              ( t (setq l (cons tr l)) ) ; tr did not meet any cond so it remain active. We store it in the swap list
            ) ; End cond
          ) ; End repeat (length al)
          (setq al l ; Restore active triangle list from the temporary list.
                l nil) ; Clear the swap list to prepare for next insertion.
          ; Removes doubled edges, calculates circumcircles and add them to al
          (while el
            (if
              (or
                (member (reverse (car el)) el)
                (member (car el) (cdr el))
              (setq el (vl-remove (reverse (car el)) el)
                    el (vl-remove (car el) el))
              (setq al (cons (getcircumcircle n (car el) pl) al)
                    el (cdr el))
        ) ; End repeat np
        ; We are done with points insertion. Any triangle left in al is added to tl
        (foreach tr al
                ctr (cons (cadr tr) ctr)) ; Added for Voronoi
        ; Extract all triangle edges from tl and form edges list el
        (setq el nil)
        (foreach tr tl
          (setq el
            (vl-list*
              (list (caddr tr) (car tr))
              (list (cadr tr) (caddr tr))
              (list (car tr) (cadr tr))
              el
        (setq el (reverse el))
        ; Here let's draw the Voronoi Diagram
        (setq vl nil)
        (foreach e el
          (setq npos (vl-position (reverse e) el)
                epos (vl-position e el))
          (if npos
            (setq vl (cons (list (/ npos 3) (/ epos 3)) vl))
            (setq vl (cons (list (- (length ctr) 1) (/ epos 3)) vl))
        (setq vor nil)
        (while vl
          (setq e (car vl)
                vl (vl-remove (reverse e) (cdr vl))
                vor (cons e vor))
        (mapcar
          (function (lambda (v)
            (list
              (nth (cadr v) ctr)
              (nth (car v) ctr)
          (cdddr ; Remove the edges of Supercircle
            (vl-sort vor
                (> (car a) (car b))
  ;; Written by  ElpanovEvgeniy        ;
  ;; 17.10.2008        ;
  ;; Calculation of the centre of a circle and circle radius                                        ;
  ;; for program triangulate        ;
  ;; Modified ymg june 2011 (renamed variables)                                                     ;
  ;; Modified ymg June 2013 to operate on Index                                                     ;
  (defun getcircumcircle (a el pl / b c c2 cp r ang vl pt)
    (setq pt (nth a pl)
          b (nth(car el) pl)
          c (nth(cadr el) pl)
          c2 (list (car c) (cadr c)) ; c2 is point c but in 2d
          vl (list a (car el) (cadr el)))
    (if (not (zerop (setq ang (- (angle b c) (angle b pt)))))
        (setq cp (polar c2 (+ -1.570796326794896 (angle c pt) ang) (setq r (/ (distance pt c2) (sin ang) 2.0)))
              r (abs r))
        (list (+ (car cp) r) cp r vl)
  (if
    (not
      (while
        (cond
          ( (not (setq ss (ssget (list (cons 0 "LWPOLYLINE")))))
            (princ "\nNothing selected. Try again...\n")
          ( (/= (sslength ss) 2)
            (princ "\nSelect 2 polylines! Try again...\n")
          ( (and
              (setq ent1 (ssname ss 0))
              (setq ent2 (ssname ss 1))
              (setq pl (append (ent->pts ent1 100) (ent->pts ent2 100)))
              (setq ent1 (vlax-ename->vla-object ent1))
              (setq ent2 (vlax-ename->vla-object ent2))
            nil ; Stop loop
      (setq s1 (_side ent1 (vlax-curve-getStartPoint ent2)))
      (setq s2 (_side ent2 (vlax-curve-getStartPoint ent1)))
      (setq vor (triangulate pl))
      (setq vor
        (vl-remove-if-not
          (function (lambda (line)
            (and
              (equal s1 (_side ent1 (car line)))
              (equal s1 (_side ent1 (cadr line)))
              (equal s2 (_side ent2 (car line)))
              (equal s2 (_side ent2 (cadr line)))
          (vl-remove-if (function (lambda (x) (or (equal x (list nil nil)) (not (car x)) (not (cadr x))))) vor)
      (if
          (distance (vlax-curve-getStartPoint ent1) (vlax-curve-getEndPoint ent2))
          (distance (vlax-curve-getEndPoint ent1) (vlax-curve-getEndPoint ent2))
        (setq start (list (vlax-curve-getEndPoint ent1) (vlax-curve-getStartPoint ent1))
              end (list (vlax-curve-getStartPoint ent2) (vlax-curve-getEndPoint ent2)))
        (setq start (list (vlax-curve-getStartPoint ent1) (vlax-curve-getEndPoint ent1))
      (setq startEnd
        (mapcar
          (function (lambda (end1 end2)
            (caar
              (vl-sort
                (mapcar
                    (list
                      line
                        (distance (car line) end1)
                        (distance (car line) end2)
                        (distance (cadr line) end1)
                        (distance (cadr line) end2)
                  vor
          start end
      (_polyline
          (lambda (lst / rtn) ; Draw a line of the midpoints of voronoi lines
            (while (cdr lst)
              (setq rtn
                (cons
                  (mapcar
                    (function (lambda (a b) (* (+ a b) 0.5)))
                    (car lst)
                    (cadr lst)
                  rtn
              (setq lst (cdr lst))
            rtn
          (minlen vor startEnd)
  • Like 4
  • Thanks 1
I now have tried a few methods, they all miss the center somewhere on the complicated "turns".
As I mentioned, even the GIS/Civil programs get similar results at times.
I did rabbit hole Bowyer–Watson algorithm and the Delaunay triangulation to obtain a Voronoi diagram of the points.
That might be over my head for LISP, I think I have seen references for Python and C# though.
I had decent results with my export to CSV and import a center line back, though still has an off center place or two on the OPs example.
  • Thanks 1
I’ve been experimenting with @lrm's tool to generate segment-by-segment bisectors. In many cases I was able to chain them together without any issues, and the equidistance was achieved.
But in the more curved areas, the bisectors produced by each pair of segments lead to results that make it impossible to connect them without losing that equidistance.
So I must apologize for my excessive optimism 😅
I guess the goal can only be to achieve true equidistance wherever it’s geometrically possible, and where it isn’t, to get the smallest deviation we can.
In the attached images you can see in red the result of using Irm’s tool segment by segment and manually joining the endpoints. The result is an equidistant centerline along most of the path. But as you can see in the area where the margins widen significantly, the geometry of the axis becomes very fuzzy.
Alongside my manual work with Irm’s tool, you can also see the output from commands "CPL" by @GP_ and "cl" by @dexus/@marko_ribar.
In fact, "cl" produces something very close to a true equidistant centerline, although it can be a bit irregular at times. And I suppose the issue with redundant points can be solved easily.
So it seems that the solution by Dexus/Ribar is the best one so far.
I added extra checks on every vertex like @PGia suggested two weeks ago.
Those I added to the offset-loop and it gives the best of both worlds.
Every point that is calculated should be the exact middle because the offset is the same on both sides.
Still not perfect, but pretty close I think.
; Calculate centerline between two polylines - dexus
; Function checks intersections of the offsets of two lines to create a middle/avarage line.
(defun c:cl (/ ent1 ent2 loop maxlen offset offsetdistance pts s1 s2 ss start LM:ProjectPointToLine LM:intersections _addPoints _avarageAngle _cornerOffset _doOffset _getAnglesAtParam _getLength _polyline _side _wait)
  ; Draw Polyline - dexus
  ; Draw a polyline from a list of points, but filter out colinear points
  ; @Param lst list of points
  ; @Returns ename of polyline
  (defun _polyline (lst / prev pts)
    (while lst
      (cond
        ((and (cdr lst) prev (null (inters prev (car lst) prev (cadr lst)))))
        ((setq pts (cons (cons 10 (setq prev (car lst))) pts)))
    (entmakex
      (append
        (list
          (cons 8 (getvar 'clayer))
          (cons 70 0)
        (reverse pts)
          der (if
                (and
                  (or
                (mapcar '-
                  (polar cpt (angle '(0 0) (vlax-curve-getFirstDeriv pline (rem (+ target 1e-3) end))) 1.0)
                  (polar cpt (angle (vlax-curve-getFirstDeriv pline (rem (+ (- target 1e-3) end) end)) '(0 0)) 1.0)
    (minusp (sin (- (angle cpt pnt) (angle '(0.0 0.0) der))))
  ;; Intersections - Lee Mac
  ;; mod - [int] acextendoption enum of intersectwith method
  (defun LM:intersections ( ob1 ob2 mod / lst rtn )
    (if
      (and
        (vlax-method-applicable-p ob1 'intersectwith)
        (vlax-method-applicable-p ob2 'intersectwith)
        (setq lst (vlax-invoke ob1 'intersectwith ob2 mod))
      (repeat (/ (length lst) 3)
        (setq rtn (cons (list (car lst) (cadr lst) (caddr lst)) rtn) lst (cdddr lst))
    (reverse rtn)
  (defun _getLength (ent)
      (vlax-curve-getDistAtParam ent (vlax-curve-getEndParam ent))
      (vlax-curve-getDistAtParam ent (vlax-curve-getStartParam ent))
  (defun _wait (msec)
    (not
        (lambda (start)
          (while (< (- (getvar 'millisecs) start) msec))
        (getvar 'millisecs)
  (defun _addPoints (lst ent pts / len)
    (setq len (_getLength ent))
    (setq lst (mapcar (function (lambda (pt) (list (/ (vlax-curve-getDistAtPoint ent pt) len) pt))) lst))
    (setq pts (append lst pts))
    ; Animation
    ;  (setq pts (vl-sort pts (function (lambda (a b) (< (car a) (car b))))))
    ;  (redraw)
    ;    (lambda (lst)
    ;      (while (cadr lst)
    ;        (grdraw (cadar lst) (cadadr lst) 3)
    ;        (setq lst (cdr lst))
    ;    pts
    ;  (vla-update ent)
    ;  (_wait 40)
    ; End animation
    pts
  (defun _doOffset (offset / te1 te2 lst rtn) ; Global vars: pts ent1 ent2 s1 s2
    (setq rtn
      (cond
        ((equal offset 0.0 1e-4)
          (if (setq lst (LM:intersections ent1 ent2 acExtendNone))
            (setq pts (_addPoints lst ent1 pts))
          lst
        ( (or ; Make offset
            (vl-catch-all-error-p (setq te1 (vl-catch-all-apply 'vlax-invoke (list ent1 'Offset (if s1 offset (- offset))))))
            (vl-catch-all-error-p (setq te2 (vl-catch-all-apply 'vlax-invoke (list ent2 'Offset (if s2 offset (- offset))))))
            (vla-put-color (car te1) 252)
            (vla-put-color (car te2) 252)
          (princ "\nOffset failed. ")
          nil
        ((setq lst (LM:intersections (car te1) (car te2) acExtendNone))
          (setq pts (_addPoints lst (car te1) pts))
          lst
    (if (and te1 (not (vl-catch-all-error-p te1))) (mapcar 'vla-delete te1))
    (if (and te2 (not (vl-catch-all-error-p te2))) (mapcar 'vla-delete te2))
    rtn
  ; Project Point onto Line - Lee Mac
  ; @Param pt point to project
  ; @Param p1 first point of line
  ; @Param p2 second point of line
  ; @Returns projected point
  (defun LM:ProjectPointToLine ( pt p1 p2 / nm )
    (setq nm (mapcar '- p2 p1)
          p1 (trans p1 0 nm)
          pt (trans pt 0 nm))
    (trans (list (car p1) (cadr p1) (caddr pt)) nm 0)
  (defun _getAnglesAtParam (ent pa / ang1 ang2)
    (if (and (vlax-curve-isClosed ent) (= pa 0)) ; Special case for closed Polyline
      (list
        (setq ang1 (vlax-curve-getFirstDeriv ent 1e-14))
        (setq ang2 (vlax-curve-getFirstDeriv ent (- (fix (vlax-curve-getEndParam ent)) 1e-14)))
      (list
        (setq ang1 (vlax-curve-getFirstDeriv ent (+ pa 1e-14)))
        (setq ang2 (vlax-curve-getFirstDeriv ent (- pa 1e-14)))
    (setq ang1 (angle '(0 0 0) ang1))
    (setq ang2 (angle '(0 0 0) ang2))
    (list ang1 (* (+ ang1 ang2) 0.5) ang2)
  ; Avarage Angle - dexus
  ; Get angle of a line between two angles
  ; @Param ang1 real - Angle in radians
  ; @Param ang2 real - Angle in radians
  ; @Returns real - Angle in radians
  (defun _avarageAngle (ang1 ang2)
    (if
        (rem (+ ang1 pi) (+ pi pi))
        (rem (+ ang2 pi) (+ pi pi))
      (+ (* (- ang2 ang1) 0.5) ang1)
      (+ (* (- ang1 ang2) 0.5) ang2)
  ; Calculate exact offset distance on a corner - dexus
  ; pt1 - Point on corner
  ; pt2 - Point on other side
  ; pt3 - Center for bisector
  ; pt4 - Target for corner of the offset
  ; pt5 - Find perpendicular point for offset distance
  ;  -------- pt1  pt5
  ;              pt4
  ;  ---- pt3 ----- pt2 -----
  ; @Param ent1 Line to check corners
  ; @Param ent2 Opposing line
  ; @Returns List of offset distances (pt1 -> pt5) to calculate
  (defun _cornerOffset (ent1 ent2 / ang1 ang2 ang3 index pt1 pt2 pt3 pt4 pt5 rtn tmp vertex)
    (setq vertex (fix (vlax-curve-getEndParam ent1))
          halfPi (* pi 0.5)
          index 0)
    (repeat vertex
      (and
        (setq pt1 (vlax-curve-getPointAtParam ent1 index)) ; Point on corner
        (setq ang1 (_getAnglesAtParam ent1 index)) ; Angles of pt1
        (setq tmp ; Temp line for finding the angle on the other side
          (entmakex
            (list
              '(0 . "line")
              (cons 10 (polar pt1 (+ (cadr ang1) halfPi) maxlen))
              (cons 11 (polar pt1 (- (cadr ang1) halfPi) maxlen))
        (setq pt2 (car (LM:intersections (vlax-ename->vla-object tmp) ent2 acExtendNone))) ; Point on other side
        (setq ang2 (_getAnglesAtParam ent2 (vlax-curve-getParamAtPoint ent2 pt2))) ; Angle of pt2
        (if (equal (rem (car ang1) pi) (rem (car ang2) pi) 1e-9) ; Is parallel?
          (and
            (setq pt3 (mapcar (function (lambda (a b) (* (+ a b) 0.5))) pt1 pt2)) ; Midpoint
            (setq ang3 (car ang1)) ; Same angle als ang1
          (and
            (setq pt3 (inters pt1 (polar pt1 (car ang1) 1) pt2 (polar pt2 (car ang2) 1) nil)) ; Find center for bisector
            (setq ang3 (_avarageAngle (angle pt1 pt3) (angle pt2 pt3))) ; Angle of bisector
        (setq pt4 (inters pt3 (polar pt3 ang3 1) pt1 (polar pt1 (+ (cadr ang1) halfPi) 1) nil)) ; Find target for corner of the offset
        (setq pt5 (LM:ProjectPointToLine pt4 pt1 (polar pt1 (+ (car ang1) halfPi) maxlen))) ; Find perpendicular point for offset distance
        (setq rtn (cons (distance pt1 pt5) rtn)) ; Return offset distance
      (if (entget tmp) (entdel tmp))
      (setq index (1+ index))
    rtn
  (if
    (not
      (while
        (cond
          ((not (setq ss (ssget '((0 . "LWPOLYLINE")))))
          ((/= (sslength ss) 2)
          ((and
            nil ; Stop loop
      (setq maxlen (* 1.1 (max (_getLength ent1) (_getLength ent2) (distance (vlax-curve-getStartPoint ent1) (vlax-curve-getStartPoint ent2)))))
      (setq offsetdistance (/ maxlen 1024.0))
      (if (LM:intersections ent1 ent2 acExtendNone)
        (setq offset (- maxlen))
        (setq offset 0.0)
      (mapcar '_doOffset (_cornerOffset ent1 ent2))
      (mapcar '_doOffset (_cornerOffset ent2 ent1))
      (while
          (setq loop
            (cond
              ((> offset maxlen) nil)
              ((_doOffset offset) (setq start t))
              ((not start) t)
              (start nil)
          (setq offset (+ offset offsetdistance))
          loop
      (if pts
        (_polyline (mapcar 'cadr (vl-sort pts (function (lambda (a b) (< (car a) (car b)))))))
  (redraw)
Edited by dexus
Changed _polyline function to filter out colinear points
  • Like 5
I'm still sorting an attempt at the Bowyer–Watson version, but first I am trying to sort a few that are getting close. The export CSV and import a centerline is very close, but on the AxisExample .dwg it has a zig-zag glitch. I have one that draws the bisector lines that's close, but still misses the midpoint coming around those turns.
I do have the one that appears very accurate on bends in one direction and the bends in the opposite direction depending on pick order. This would work if the AxisExample.dwg was in separate sections at the turns, maybe.
I get a error: bad argument type: fixnump: nil with the AxisExample.dwg and some other errors on the original Example.dwg (Two vertices were added to a 2D pline (0) which had no vertices. and error: bad argument type: numberp: nil ) though the simple ones it draws the centerline with @marko_ribar's version.
Every one of these fall short on the OPs AxisExample drawing, most in the same areas. So, I will probably keep at this for a while to see how close I can get it.
For sure, nearly everyone of these are as good as and many much better than, the currently available solutions in AutoCAD.
The solution suggested by Autodesk, PathAverage.lsp by Kent Cooper, fails miserably on most of the OP's examples, though seems to work in most cases and needs the polylines in the same direction.
I still have work to do for my paying job, but hopefully I can bang out something soon.
  • Agree 1
    (entmakex
      (append
        (list
          (cons 70 0)
          der (if
                (and
                  (or
                (mapcar '-
    (if
      (and
    (reverse rtn)
  (defun _wait (msec)
    (not
        (lambda (start)
        (getvar 'millisecs)
    ; Animation
    ;  (redraw)
    ;    (lambda (lst)
    ;      (while (cadr lst)
    ;    pts
    ;  (vla-update ent)
    ;  (_wait 40)
    ; End animation
    pts
    (setq rtn
      (cond
          lst
        ( (or ; Make offset
          nil
          lst
    rtn
          p1 (trans p1 0 nm)
          pt (trans pt 0 nm))
      (list
      (list
    (if
  ;  -------- pt1  pt5
  ;              pt4
          halfPi (* pi 0.5)
          index 0)
    (repeat vertex
      (and
          (entmakex
            (list
              '(0 . "line")
          (setq pt3 (mapcar (function (lambda (a b) (* (+ a b) 0.5))) pt1 pt2) ; Midpoint
          (setq pt3 (inters pt1 (polar pt1 (car ang1) 1) pt2 (polar pt2 (car ang2) 1) nil) ; Find center for bisector
    rtn
  (if
    (not
      (while
        (cond
          ((and
            nil ; Stop loop
        (setq offset 0.0)
      (while
          (setq loop
            (cond
              ((not start) t)
              (start nil)
          loop
      (if pts
  (redraw)
I think you're doing a very good job.
PS: The animation in the GIF doesn't look the same as the one in the code.
  • Thanks 1
Thanks.
The animation in the GIF is from the calculations made in _cornerOffset.
When it was (finally 🫣) working I replaced the animation code with error checking.
Didn't take the time to make it do both, but I did want to show how it worked here.
In the voronoi version some error checking before trying to call _polyline should be added indeed.
And this function is dependent on how well the points are distributed over the line (ent->pts function).
For the lines close together, more points should be given and with crossing lines it will not work at all.
It only works if the lines stay in between the two polylines, and it doesn't in the example from OP:
Hi,
I’ve tested @dexus's code and it’s definitely the best one that has appeared so far.
I only found a small discrepancy in one area where it seems that obtaining the correct centerline is actually possible (see the first image).
Everywhere else, the centerline seems to have been achieved whenever it was geometrically feasible.
One small point that might be improved is in the area where the margins widen (as shown in the second image).
Although getting a truly equidistant centerline is impossible there, it might still be worth trying to ensure that the perpendiculars to the centerline hit each margin at distances that aren’t too different from each other.
As you can see in the image, there’s a section of the centerline (near the point where it turns north) where the right margin falls outside the acceptable range.
I think @lrm's bisectors give a good hint of the path the centerline should follow in order to avoid this.
Anyway, the result obtained by Dexus's code is one of the best (perhaps the best) I've found on the web.
Thanks for that, Dexus 😃
  • Thanks 1
I have a few doing pretty good, but as you show, there is no one perfect way. I broke your Axis Example.dwg into one bend area per section and several of the LISPs did a lot better.
If you have a .dwg with any more difficult sections like the one shown, please post it.
I'm not back to work until Monday, but will try to find time at home to fine tune a LISP solution.
18 hours ago, PGia said:
... trying to ensure that the perpendiculars to the centerline hit each margin at distances that aren’t too different from each other...
The concept is incorrect. To be equidistant, every point on the centerline must be the same distance (perpendicular) from the two margins.
  • Agree 1
@PGia Thanks for the encouragement and checking the results.
I measure from the vertices instead of the lines. Those are calculated and the lines are just to connect the points.
So perpendicular to the middle of segments of the centerline will always be a bit off, but if you measure from the vertices it should be centered correctly. Just like @GP_ said.
I kept going in the same direction and I have made some improvements and got rid of some bugginess:
  • The centerline should be a little more accurate now because of extra measurements (blue line)
  • Crossing polylines get sharp corners on negative side
  • Corner checks are done on all intersections of temporary line now (red line)
  • More error checking so it doesn't crash on some of the example lines
  • I left all of the 'animation' code commented out so you can give it a try
; https://www.cadtutor.net/forum/topic/98778-hybrid-parallel/page/6/#findComment-677339
; Version 0.1 - Initial release 19-11-2025
; Version 0.2 - Added corner support on negative side of crossing polylines 27-11-2025
; Version 0.3 - Extra check using vertex to closest point as distance 28-11-2025
; Version 0.4 - Added error function 28-11-2025
; Version 0.5 - Improved distance check to prevent zigzag lines 01-12-2025
; Version 0.6 - Check if offset can be used before adding points 01-12-2025
; Version 0.7 - Improved side check on 3 points 01-12-2025
(defun c:cpl (/ corners ent1 ent2 enx2 flipped loop maxlen offset offsetdistance pts sides ss start te0 te1 te2 LM:ProjectPointToLine LM:intersections _addPoints _avarageAngle _checkOffset _cornerOffset _doOffset _getAnglesAtParam _getLength _polyline _rlw _side _wait *error*)
  (defun *error* (st)
    (if (wcmatch (strcase st t) "*break,*cancel*,*exit*")
      (redraw)
      (vl-bt)
      (princ (strcat "\nOops! Something went wrong: ") st)
    (if (not (vlax-erased-p te0)) (entdel te0))
  (defun _polyline (lst closed / prev pts)
    (while lst
      (cond
          (and (cdr lst) prev
            (or
              (equal (cdr lst) prev 1e-8) ; Remove duplicate points
              (null (inters prev (car lst) prev (cadr lst))) ; Remove collineair points
    (entmakex
      (append
        (list
          (cons 70 (if closed 1 0))
        (reverse pts)
  (defun _side (pline pnt / cpt end target der) ; https://www.theswamp.org/index.php?topic=55685.msg610429#msg610429
          der (if
                (and
                  (or
                (mapcar '-
    (if
      (and
    (reverse rtn)
  (defun _wait (msec)
    (not
        (lambda (start)
        (getvar 'millisecs)
  (defun _addPoints (lst ent1 ent2 pts / len1 len2)
    (setq len1 (_getLength ent1)
          len2 (_getLength ent2)
          lst
            (vl-remove nil
              (mapcar
                (function (lambda (pt / d1 d2)
                  (if
                    (and
                      (setq d1 (vlax-curve-getDistAtPoint ent1 pt))
                      (setq d2 (vlax-curve-getDistAtPoint ent2 pt))
                    (list (+ (/ d1 len1) (/ d2 len2)) pt)
                lst
    ; Animation
    ;  (redraw)
    ;  (foreach pt lst
    ;    (tmpPoint (cadr pt) 1 1)
    ;    (lambda (lst)
    ;      (while (cadr lst)
    ;        (grdraw (cadar lst) (cadar (setq lst (cdr lst))) 3)
    ;    pts
    ;  (vla-update ent1)
    ;  (_wait 40)
    ; End animation
    pts
  (defun _checkOffset (ent1 ent2 offset)
    (and
      (equal (distance (vlax-curve-getStartPoint ent1) (vlax-curve-getStartPoint ent2)) offset 1e-4)
      (equal (distance (vlax-curve-getEndPoint ent1) (vlax-curve-getEndPoint ent2)) offset 1e-4)
  (defun _doOffset (offset / lst rtn) ; Global vars: pts ent1 ent2 sides te1 te2
    (setq te1 nil)
    (setq te2 nil)
    (setq rtn
      (cond
        ((equal offset 0.0 1e-8)
            (setq pts (_addPoints lst ent1 ent2 pts))
          lst
        ( (or ; Make offset
            (vl-catch-all-error-p (setq te1 (vl-catch-all-apply 'vlax-invoke (list ent1 'Offset (if (car sides) offset (- offset)))))) (cdr te1)
            (vl-catch-all-error-p (setq te2 (vl-catch-all-apply 'vlax-invoke (list ent2 'Offset (if (cadr sides) offset (- offset)))))) (cdr te2)
            (not (_checkOffset ent1 (car te1) offset))
            (not (_checkOffset ent2 (car te2) offset))
            (vla-put-visible (car te1) :vlax-false)
            (vla-put-visible (car te2) :vlax-false)
          nil
          (setq pts (_addPoints lst (car te1) (car te2) pts))
          lst
    rtn
          p1 (trans p1 0 nm)
          pt (trans pt 0 nm))
    (if (and ang1 ang2)
      (list
    (if
  ;  -------- pt1  pt5
  ;              pt4
  (defun _cornerOffset (ent1 ent2 / ang1 ang1a ang2 ang3 index pt1 pt2 pt3 pt4 pt5 rtn)
    (setq index 0)
    (repeat (fix (vlax-curve-getEndParam ent1))
      (and
        (setq ang1a (_avarageAngle (car ang1) (cadr ang1)))
        (setq te0 (entmakex (list (cons 0 "line") (cons 10 pt1) (cons 11 (polar pt1 (- ang1a halfPi) 1))))) ; Temp line for finding the angle on the other side
        (foreach pt2 (LM:intersections (vlax-ename->vla-object te0) ent2 acExtendThisEntity) ; Point on other side
          (and
            (if (equal (rem (car ang1) pi) (rem (car ang2) pi) 1e-8) ; Is parallel?
              (and
              (and
            (setq pt4 (inters pt3 (polar pt3 ang3 1) pt1 (polar pt1 (+ ang1a halfPi) 1) nil)) ; Find target for corner of the offset
            ; Animation
            ;  (progn
            ;    (redraw)
            ;    (grdraw pt1 pt2 1)
            ;    (grdraw pt4 pt5 2)
            ;    (grdraw pt1 pt5 2)
            ;    (grdraw pt2 pt5 2)
            ;    (vla-update ent1)
            ;    (_wait 120)
            ; End Animation
    rtn
  (defun _rlw (lw / x1 x2 x3 x4 x5 x6)
    (if (and lw (= (cdr (assoc 0 lw)) "LWPOLYLINE"))
        (foreach a1 lw
          (cond
            ((= (car a1) 10) (setq x2 (cons a1 x2)))
            ((= (car a1) 40) (setq x4 (cons (cons 41 (cdr a1)) x4)))
            ((= (car a1) 41) (setq x3 (cons (cons 40 (cdr a1)) x3)))
            ((= (car a1) 42) (setq x5 (cons (cons 42 (- (cdr a1))) x5)))
            ((= (car a1) 210) (setq x6 (cons a1 x6)))
            (t (setq x1 (cons a1 x1)))
        (append
          (reverse x1)
          (append (apply (function append) (apply (function mapcar)
            (cons 'list (list x2
              (cdr (reverse (cons (car x3) (reverse x3))))
              (cdr (reverse (cons (car x4) (reverse x4))))
              (cdr (reverse (cons (car x5) (reverse x5))))
          )) x6)
  (if
    (and
      (not
        (while
          (cond
            ((and
                (setq enx2 (entget ent2))
              nil ; Stop loop
      ent1
      ent2
      (and
        (setq flipped t)
        (entmod (_rlw enx2))
      (setq sides
        (mapcar
          (function (lambda (a b / s m e)
            (setq s (_side a (vlax-curve-getStartPoint b))
                  m (_side a (vlax-curve-getPointAtParam b (* 0.5 (vlax-curve-getEndParam b))))
                  e (_side a (vlax-curve-getEndPoint b)))
            (or (and s m) (and s e) (and m e))
          (list ent1 ent2)
          (list ent2 ent1)
      (if (not (numberp halfPi)) (setq halfPi (* pi 0.5)))
      (setq maxlen
        (* 1.1
          (max
            (_getLength ent1)
            (_getLength ent2)
              (lambda (ent1 ent2 / step de1 div p_step dis dmax)
                (setq step (/ (setq de1 (vlax-curve-getDistAtParam ent1 (vlax-curve-getEndParam ent1))) 500)
                      div step
                      dmax 0.00)
                (while (< div de1)
                  (setq p_step (vlax-curve-getPointAtDist ent1 div)
                        dis (distance p_step (vlax-curve-getClosestPointTo ent2 p_step)))
                  (if (> dis dmax) (setq dmax dis))
                  (setq div (+ div step))
                dmax
              ent1 ent2
      (mapcar ; Add half distances from closest point to every vertex
        (function (lambda (ent1 ent2 / index pt)
          (setq index 0)
            (setq pt (vlax-curve-getPointAtParam ent1 index)
                  corners (cons (* (distance pt (vlax-curve-getClosestPointTo ent2 pt)) 0.5) corners)
                  index (1+ index))
            ; Animation
            ;  (redraw)
            ;  (grdraw pt (vlax-curve-getClosestPointTo ent2 pt) 4)
            ;    (lambda (mid) (grdraw mid (polar mid (+ (angle pt (vlax-curve-getClosestPointTo ent2 pt)) halfPi) (car corners)) 2))
            ;    (mapcar (function (lambda (a b) (* (+ a b) 0.5))) pt (vlax-curve-getClosestPointTo ent2 pt))
            ;  (vla-update ent1)
            ;  (_wait 120)
            ; End animation
        (list ent1 ent2)
        (list ent2 ent1)
      (setq corners (vl-sort (append corners (_cornerOffset ent1 ent2) (_cornerOffset ent2 ent1)) '<)
            offsetdistance (/ maxlen 512.0))
      (if (LM:intersections ent1 ent2 acExtendNone) ; For crossing polylines, add negative values
        (setq offset (- maxlen) corners (append (mapcar '- (reverse corners)) corners))
        (setq offset 0.0)
      (while
          (while (and corners (> offset (car corners))) ; Calculated offset values to check
            (_doOffset (car corners))
            (setq corners (cdr corners))
          (setq loop ; Incremental check
            (cond
              ((not start) t)
              (start nil)
          loop
      (if flipped (entmod enx2))
      (if pts ; Draw polyline
        (_polyline
          (and (vlax-curve-isClosed ent1) (vlax-curve-isClosed ent2))
  (redraw)
And here is an animation of it working just because they are fun to look at 😆:
Edited by dexus
  • Like 4
  • Thanks 1
I’ve always thought that a centerline should keep the same distance to the left and right, in the direction of travel.
But from a geometric standpoint, maybe it should be as you say.I won’t get into that controversy.
Perhaps that approach does make it possible to obtain the centerline in more situations.
Regarding @SLW210’s suggestion that I upload a drawing to put the proposed Lisp codes to the test, I think the most appropriate example is the bank of a small river.
I trimmed a section and ran the codes by @dexus, @Lee Mac, @SLW210, @mhupp, and @GP_ on it.
The geometry of the riverbanks seems to be quite stressful for all the codes, although Dexus’s code only loses control in a couple of areas.
I’m attaching the file with all of this for anyone who wants to take a look.
AxisExple2.dwg
Edited by PGia
  • Thanks 1
Nice test case @PGia, it did have some undesirable zigzags on those lines.
I made some changes to the code to prevent this from happening.
It should create a smooth line again! 😁
Edited by dexus
Updated code in previous post!
  • Like 5
Just thought what would using a TIN, only drawback was TIN needed a lot of editing before joining mid points of mesh or lines. It is close to the orange linework. White lines are just that where TIN's have been removed.
Edited by BIGAL
@BIGAL  that was the essence of my suggestion about 100 posts ago (October 22).  The results rely to heavily on the relative distribution of vertices (quantity and spacing)  between the two polylines.
Thanks LRM i do admit the task has a lot of posts and probably skipped over the one about using TIN's.
Ufff…
I see a lot has happened in this thread since my last visit 😅
I’ve been busy with a couple of very urgent matters, but I’m going to try to catch up again.
The results achieved by Dexus are very good.
It seems there’s not much left to improve.
Maybe getting a simpler and faster code?
Also, the problem of the “recodos/inlet/recess” is still there: as long as there isn’t a code that can compute a centerline for two margins, whether they have recodos/inlets/recesses or not, there will continue to be thousands of unsuccessful searches for this problem on the web.
I think finding a solution for this is a good goal.
I’ll try to focus my next piece of code in that direction.
