Civil 3D deleting subentities from alignements
When i (not always,not every drawing or from the first time)delete a subentity(curve,tangent,spiral)autocad freezes(is not responding).
HELP???:shock::huh::acad:
Even if you sit back and give it time to digest the manipulation?
:o:?:huh::(
ie - You are giving it plenty of time to think (process) after you delete the sub-entity like the patient person I'm sure you are.
he means basically give it a chance, if you are not doing so already, is the problem still there existing?
i have to go to the taskmanager to end the autocad process,so it's not a question of having a slow computer,it just jams up:wink:
I would also suggest considering to upgrade to the latest version if you can. If your info are correct that you're using C3D 2006, you are now missing a lot of features of the newer versions.
I have the 2009 version that's completely updated.
I think it's a bug.
