fpanjsh4 Posted November 28, 2011 Share Posted November 28, 2011 Is there a command to extrude something at like a an angle. Im not talking about taper but something that could extrude at an angle Quote Link to comment Share on other sites More sharing options...
BIGAL Posted November 28, 2011 Share Posted November 28, 2011 You can extrude an object at any any 3D angle you need to look into UCS, you just create a new ucs draw object then extrude. Quote Link to comment Share on other sites More sharing options...
Patrick Hughes Posted November 28, 2011 Share Posted November 28, 2011 You can extrude an object at any any 3D angle you need to look into UCS, you just create a new ucs draw object then extrude. I'm not certain I follow you BIGAL, I haven't tried adjusting the UCS to extrude. I've extruded at an angle by drawing a line into the z-axis and rotating it to the angle I want (or the line could be drawn to the angle you want) then extrude using the line as the path. Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 28, 2011 Share Posted November 28, 2011 Is there a command to extrude something at like a an angle. Im not talking about taper but something that could extrude at an angle Do you know how to reorient your UCS? Yes/No/What is a UCS? Quote Link to comment Share on other sites More sharing options...
Organic Posted November 28, 2011 Share Posted November 28, 2011 Do you know how to reorient your UCS? Yes/No/What is a UCS? The UCS is one of the more complicated features of AutoCad remember. Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 28, 2011 Share Posted November 28, 2011 (edited) Yes, I remember. What is it that you are expecting me to do? I'll take a wild guess here and assume you want me to tell the OP how to manipulate the UCS. 1) Manually...from the command line. Ex. - UCS > X > 90. Make sure your UCS icon is showing. UCSICON > On. 2) Via the Ribbon. In a 3D Modeling workspace look on either the Home or View tabs for the Coordinate panel. Multiple choices for orienting the UCS icon are available. 3) Allow/Disallow Dynamic UCS (F6 key to toggle). There is a button for this in the lower left-hand corner of your screen sandwiched between the ones for Object Snap Tracking and Dynamic Input. Edited November 28, 2011 by ReMark Quote Link to comment Share on other sites More sharing options...
JD Mather Posted November 28, 2011 Share Posted November 28, 2011 Is there a command to extrude something at like a an angle. Im not talking about taper but something that could extrude at an angle Attach 2d drawing representative of what you are trying to do. Perhaps Sweep is the easiest answer to your problem. Quote Link to comment Share on other sites More sharing options...
Alex Moiceanu Posted December 2, 2011 Share Posted December 2, 2011 Try to create a line at the angle you want to extrude and sweep the area with line set as path. Quote Link to comment Share on other sites More sharing options...
Bill Tillman Posted December 3, 2011 Share Posted December 3, 2011 I'll take a wild guess here and assume you want me to tell the OP how to manipulate the UCS. Manipulating my UCS...not since I was a teenager.....er, oh, sorry, Yes, the UCS is our friend and if you're trying to do things in 3D it is highly recommended that you master this feature of AutoCAD. I was confused when I started with it too, and even today sometime I find that it takes me a couple of tries to get the rotation about the correct axis as I need it. But once I got this understood, the 3D world really opened up for me. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted December 3, 2011 Share Posted December 3, 2011 you might want to explore the UCS FACE icon on the UCS toolbar. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted December 3, 2011 Share Posted December 3, 2011 I think the OP is long gone. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 7, 2011 Share Posted December 7, 2011 Pity I was going to paste how to make a 3d TIN surface model with a base elevation into a 3d solid so it has a "thicknes rather than wafer thick as an example of using ucs re borehole logs. Quote Link to comment Share on other sites More sharing options...
