lutzow10 Posted November 9, 2017 Share Posted November 9, 2017 (Here is a link to the original post I am referencing) Hi Guys, I found this awesome lisp by Renderman/Black Box and I have run it a few times and it worked great those times. Then I tried to run it to convert maybe 20 wipeouts at once and a bunch of them disappeared. I would really like to be able to use this one time once I finish drawing all the wipeouts and not after everyone, but I also don't want to risk some failing to convert and having to redraw a bunch of them. Does anyone see anything that would cause these errors? ;;;--------------------------------------------------------------------; ;;; c:WIPEOUT->REGION ;;; Courtesy of RenderMan, CADTutor.net ;;;--------------------------------------------------------------------; ;;; Description: ;;; Convert all wipeouts within a given drawing to regions. ;;;--------------------------------------------------------------------; ;;; Exit function: (defun WIPEOUT->REGION:Exit (msg) (cond ((not msg)) ; Normal exit ((member msg '("Function cancelled" "quit / exit abort"))) ; <esc> or (quit) ((princ (strcat "\n <!> Error: " msg " <!> ")))) ; Fatal error, display it (WIPEOUT->REGION:Quit)) ;;;--------------------------------------------------------------------; ;;; Quit function: (defun WIPEOUT->REGION:Quit () (setvar 'cmdecho *oldCmdecho*) (setq *oldCmdecho* nil) (setq *error* *oldError* *oldError* nil) (vla-endundomark *activeDoc*) (princ)) ;;;--------------------------------------------------------------------; ;;; Main function: (defun c:WIPEOUT->REGION (/ ss) (vl-load-com) (vla-startundomark (cond (*activeDoc*) ((setq *activeDoc* (vla-get-activedocument (vlax-get-acad-object)))))) ;; Error checking (setq *oldError* *error* *error* WIPEOUT->REGION:Exit) (setq *oldCmdecho* (getvar 'cmdecho)) (setvar 'cmdecho 0) ;; Main code (if (and (setq ss (ssget "_x" '((0 . "WIPEOUT")))) (setq ss (ssget "_x"))) ((lambda (i / e v visList wipList mn mx c) (while (setq e (ssname ss (setq i (1+ i)))) (if (/= "WIPEOUT" (strcase (cdr (assoc 0 (entget e))))) (progn (vla-put-visible (setq v (vlax-ename->vla-object e)) :vlax-false) (setq visList (cons v visList))) (setq wipList (cons e wipList)))) (foreach w wipList (vla-getboundingbox (setq v (vlax-ename->vla-object w)) 'mn 'mx) (setq c (mapcar '* (mapcar '+ (setq mn (vlax-safearray->list mn)) (setq mx (vlax-safearray->list mx))) '(0.5 0.5 0.5))) (vl-cmdf "._boundary" c "") (vl-cmdf "._matchprop" w (entlast) "") (vl-cmdf "._region" "") (vla-delete v)) (foreach o visList (vla-put-visible o :vlax-true))) -1) (prompt "\n <!> No Wipeouts Detected in Currect Drawing <!> ")) (WIPEOUT->REGION:Quit)) Quote Link to comment Share on other sites More sharing options...
