abeltran Posted May 5, 2013 Share Posted May 5, 2013 (edited) Hi I am having a little problem changing the visibility and the date on this dynamic block thru the command line .the resend I want to do this is because I want to write a script that can change the visibility and the date. I try changing the date with GATTE and –ATTEDIT and it doesn’t change the date and with the visibility I don’t know any commands that can change. If you can please find a way to change that and make a script I will really appreciated. Thank you Here is the block RED_STAMP.dwg Edited June 19, 2013 by abeltran Quote Link to comment Share on other sites More sharing options...
