The never ending story: Polyline export to file
elfert
Hello Lisp forum!
Can you help i found this thread:
http://www.cadtutor.net/forum/showthread.php?9628-Export-Points
I need a lisp routine thats could export polylines to a file called infile and it should look the same as the attached one. the file should be placed in the folder C:\user\ and if the routines can't find the folder it should create it.
Many many many thx in advance.
infile.txt
  • Replies 48
  • pBe
    15
  • elfert
    11
  • Kapanther
    8
  • SolarPVDesigner
    4
Hello Lisp forum!
Just a hint, sorry
I had similar problem earlier on my machine
Make sure you have user permissions to
this folder "C:\user\" before
Just a hint, sorry
Okay but i am not sure where to start changing the lisp routine ? I found this made by mfuccaro, thx mfuccaro. But i need it to make the file in C:\user\ and it should make the file similar to the one attached with the same filename. This about logname, logfilename ect. i am not sure how to use that? The problem is that we today use a VBA to do it but we change to 64 bit OS and AC and in the future VBA is not supported by AC. So thats why i need a lisp routine to be in a language that ac whould understand in the future. thx in advance.
;export old style polyline vertex coords to a text file
;	mfuccaro@hotmail.com
(defun c:pl2txt ( / en ask i a file)
 (while (not ask)
   (setq en (car (entsel)))
   (if en (setq ask (= "LWPOLYLINE" (cdr (assoc 0 (entget en))))))
 (setq file (open (getfiled "Output file"
		     (strcat (getvar "dwgprefix")
		     (substr (getvar "DWGNAME") 1 (- (strlen (getvar "dwgname")) 4)))
		     "txt"     ;file type
		     1) "w"))
 (setq i 0 sep ";")	;sep=separator
 (while (or (zerop i) a)
   (setq a (mapcar 'rtos (cdr (assoc 10 (entget (setq en (entnext en)))))))
   (if a (write-line (strcat (car a) sep (cadr a) sep (caddr a)) file))
   (setq i (1+ i))
 (close file)
 (princ (strcat "\n" (itoa (1- i)) " points exported"))
[/code]
Dont worry about it effert, i'm just showing you the lazy way of exporting data. ;) I'm in that mode now :lol:
In any case .. Oleg got you covered.
I found the code at afralisp and i want to retrive the z-coordinates but i can't make it do it correct can some body help , Please? Is it possible to make the file go in to the C:\user\ folder as it is now i always end up in the 'My document'. I the folder dosn't exist the will be okay report back to the user.
http://www.afralisp.net/visual-lisp/tutorials/polylines-part-1.php
(prompt "\nType \"vlplexport\" to run........")
(defun c:vlplexport ( / theobj thelist n xval yval zval fname fn)
;load the visual lisp extensions
(vl-load-com)
;get the entity and entity name
(setq theobj (car (entsel "\nSelect a Polyline: ")))
;convert to vl object
(setq theobj (vlax-ename->vla-object theobj))
;check if it's a polyline
(if (= (vlax-get-property theobj 'ObjectName) "AcDbPolyline")
;if it is, do the following
;retrieve the coordinates
(setq thelist (vlax-get-property theobj 'coordinates))
;convert to a list
(setq thelist (vlax-safearray->list  (variant-value thelist)))
;zero the counter
(setq n 0)
;create a text file
(setq fname "infile")
;open it to write
(setq fn (open fname "w"))
;write the header
(write-line "PolyLine X, Y and Z Coordinates" fn)
;underline the header
(write-line "*****************************************" fn)
;start the loop
(repeat (/ (length thelist) 3)
;get the x coordinate
(setq xval (rtos (nth n thelist)))
;increase the counter
(setq n (1+ n))
;get the y coordinate
(setq yval (rtos (nth n thelist)))
(setq n (1+ n))
;get the z coordinate
(setq zval (rtos (nth n thelist)))
;write the x coordinate to the file
(write-line  (strcat "X-Value : " xval)  fn)
;write the y coordinate to the file
(write-line  (strcat "Y-Value : " yval)  fn)
;write the z coordinate to the file
(write-line  (strcat "z-Value : " zval)  fn)
;add a seperator
(write-line "-----------------------------" fn)
(setq n (1+ n))
);repeat
;close the file
(close fn)
);progn
;it's not a polyline, inform the user
(alert "This is not a Polyline! - Please try again.")
);if
);defun
;clean loading
;End of VL-POLY.LSP
Many txh in advance.
See these functions in the Help file:
;check if folder exist
(if (not (vl-file-directory-p "c:/User"))
   (alert "Does not exist. Create one...")
   (vl-mkdir "c:/User")
 ;check again, who knows?
   (if (vl-file-directory-p "c:/User")
(alert "Now it was created. Go to write your data")
;;write data here
  (alert "Exist. You can write your data")
  ;;write data here
~'J'~
;;write data here
  ;;write data here
~'J'~
Thx. Fixo for that
Try this code and select a Polyline and after that select 3dpoly ..
(defun c:TesT (/ ss lst)
 (if (setq ss (car (entsel "\n Select Polyline :")))
     (vl-remove-if-not
       (function
         (lambda (x)
           (if (eq (car x) 10)
             (setq lst (cons (cons (cadr x) (caddr x)) lst))
       (entget ss)
     (princ lst)
I am starting to getting there but i can't make it take out the same x, y values as the same as list do, please help:
(defun c:vlplexport ( / theobj n thelist xval yval fname fn)
(vl-load-com)
;convert to a list
;Check if folder exits
   (alert "Does not exist. Creating one...")
(alert "Now it was created. I am Going to write your data")
;zero the counter
(setq n 0)
;open it to write
(setq fn (open "c:/user/infile" "w"))
;start the loop
(repeat (/ (length thelist) 4)
(setq n (1+ n))
(setq n (1+ n))
;(setq zval (rtos (nth n thelist)))
(write-line  (strcat "          at point  X= " xval "  Y= " yval "  Z= 0.0000")  fn)
(setq n (1+ n))
);repeat
;close the file
(close fn)
);progn
);if
);defun
;clean loading
;End of VL-POLY.LSP
thx in advance. I think it has something to do with the repeat command but i am not sure?
The way is see it.
- you can prompt for file name
- use getfiled function
- hardcode the filename.
- use DWGNAME variable as filename
(defun c:vlplexport  (/ AT:GetVertices strnum [b][color=blue]_dxf[/color][/b] theobj fn thelist [color=blue][b]pref f[/b][/color])
     (defun AT:GetVertices  (e / p l)
           ;; Return point at each vertex of curve
           ;; e - curve to evaluate (Arc, Line, *Polyline, Spline)
           ;; Alan J. Thompson, 09.30.10
           (if e
                 (if (eq (setq p (vlax-curve-getEndParam e))
                         (fix p))
                       (repeat (setq p (1+ (fix p)))
                             (setq l    (cons (vlax-curve-getPointAtParam
                                                    e
                                                    (setq p    (1- p)))
                                              l))
                       (list (vlax-curve-getStartPoint e)
                             (vlax-curve-getEndPoint e))
     (defun strnum  (str val / p)
           (setq p " ")
           (repeat (- val (strlen str))
                 (setq p (strcat " " p)))
           (strcat str p))
     [color=blue][b](defun _dxf (ent dx)(cdr (assoc dx (entget ent))))
[/b][/color]      (vl-mkdir "c:/User")
    [color=blue][b] (setq fn (open (setq f "c:/user/infile.txt") "w"))
[/b][/color]      (prompt "\nSelect a Polyline: ")
     (while (and fn (setq theobj (ssget ":S:E" '((0 . "*LINE")))))
           (setq thelist [color=blue][b](if (eq (_dxf (setq e (ssname theobj 0)) 0) "LINE")
                              (progn (setq pref '("S" "E")) (list (_dxf e 10)(_dxf e 11)))
[/b][/color]    (AT:GetVertices e))[b][color=blue])[/color][/b]
           (redraw e 3)
           (foreach
                  itm  thelist
                 (write-line
                       (strcat [color=blue][b](if pref
                                   (strcat "                 " (car pref) "  X =")
                                   "          at point  X =")
[/b][/color]                                (strnum (rtos (Car itm) 2 4) 10)
                               "Y= "
                               (strnum (rtos (Cadr itm) 2 4) 10)
                               "Z= "
                               (strnum (rtos (last itm) 2 4) 10))
                       fn)
                 (setq pref (cdr pref))
     [color=blue][b](close fn)
[/b][/color]      [b][color=blue](startapp "notepad" f)
[/color][/b]      (vla-regen (vla-get-ActiveDocument (vlax-get-acad-object)) acActiveViewport)
*kudos to Alanjt*
HTH
NOTE:
DIMZIN 3 or 0
open will "append" ("a") the file rather than overwriting ("w") the data
CODE UPDATED:
Unique prefix for LINE entity, "S" for start point "E" for Endpoint.
Opens infile.txt file with notepad at end of program.
Replace "a" with "w" and relocate open/close function for loop.
Edited by pBe
Update Code
Polyline has only X and Y , and only the 3dpoly has the Z coordinates .
LWpolyline always has zero value and it can not be others than zero because it's a 2d coordinates as far as I know .
Constant "Z" value but not always zero
(Elevation = "Z")
The way is see it.
(defun c:vlplexport  (/ AT:GetVertices strnum theobj fn)
           (if e
                         (fix p))
                                                    e
                                                    (setq p    (1- p)))
                                              l))
           (setq p " ")
           (strcat str p))
     (while (setq theobj (ssget ":S:E" '((0 . "*LINE"))))
           (setq thelist (AT:GetVertices (setq e (ssname theobj 0))))
           (setq fn (open "c:/user/infile.txt" "a"))
           (redraw e 3)
           (foreach
                  itm  thelist
                 (write-line
                       (strcat "          at point  X ="
                               "Y= "
                               "Z= "
                       fn)
           (close fn)
           )(vla-regen (vla-get-ActiveDocument (vlax-get-acad-object)) acActiveViewport)
*kudos to Alanjt*
HTH
NOTE:
DIMZIN 3 or 0
Thx very much can do a ;; around in the lisp routine i need to lean what it is doing! Thx in advance.
