Guest Posted March 5, 2017 Share Posted March 5, 2017 Hi. I want to ask a question about the paper size. I have many paper sizes in my ploter but every time i need to select one i have to search a lot of time because this plotter styles list is in radom position. Is any way to put all this paper size in a correct list.look the attach photo Thanks Quote Link to comment Share on other sites More sharing options...
Guest Posted March 5, 2017 Share Posted March 5, 2017 any option ? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 6, 2017 Share Posted March 6, 2017 See if you can find another Dwg to PDF.pc3 someone has had a good play with yours. DWG To PDF.zip Quote Link to comment Share on other sites More sharing options...
Guest Posted March 6, 2017 Share Posted March 6, 2017 Is possible to be fixed with a lisp code? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 7, 2017 Share Posted March 7, 2017 Did you try what I posted make sure you keep old pc3 ? Its obvious to me that you have lengthed A1 sheets of all sorts of sizes not sure why if you must have this huge array of sizes then have only one you can edit the values then plot. Just pick the properties box in the plot display and then custom paper size, then the edit button, change the one dimension and overwrite, then plot. Quote Link to comment Share on other sites More sharing options...
Guest Posted March 7, 2017 Share Posted March 7, 2017 Hi BIGAL . If i change the the DWG To PDF with another i will loose all the paper sizes i have. I need to have a list of paper sizes. In the plotter properlies ->custom papers -> Add thee list of papers is correct but in page setup tab like the photo the paper sizes is radom. Is it normal ? Is any way to put all this paper sizes is correct list? Quote Link to comment Share on other sites More sharing options...
