Building a Point List
Bill Tillman
I haven't tried this in a while but what I need to do is to build a list of points which can be used to construct a polyline.
(setq pt1 '(0.0 0.0)
       pt1 (append pt1 (list (car pt1) (+ (cadr pt1 12)))
       pt1 (append pt1 (list (+ (car pt1 12) (+ (cadr pt1) 12)))
But I'm not ending up with what I was intending to, which is
((0.0 0.0) (0.0 12.0) (12.0 12.0))
And this then begs the question, is it better to assembly a list of lists or just a list of the car/cadr of each point
(0.0 0.0 0.0 12.0 12.0 12.0)
When it's said and done I want to use entmake to construct the polyline using the points list.
Here are 2 common ways to construct a list:
(defun test ( / p pL ) ; #1
 (while (setq p (getpoint "\nSpecify point: "))
   (setq pL (cons p pL)) ; items are collected in reverse order
 (reverse pL)
(defun test ( / p pL ) ; #2
   (setq pL (append (list p) pL)) ; items are collected in order
As for the polyline emaking, check this thread.
(append list1 list2) is adding each element of list2 to the end of list1
Observe each or this sample:
(append (list 1) (list 2))                   -> (1 2)
(append (list 1 2) (list 3 4))               -> (1 2 3 4)
(append (list (list 1 2)) (list (list 3 4))) -> ((1 2) (3 4))
If you want a list of points, you have to feed the append function with lists of points, each point being a list of numbers (X, Y coordinates). In your sample, all lists are list of numbers.
These 2 samples are equivalent:
(setq pt1 '((0.0 0.0))
     pt1 (append pt1 (list (list (caar pt1) (+ (cadar pt1) 12))))
     pt1 (append pt1 (list (list (+ (caar pt1) 12) (+ (cadar pt1) 12))))
     pt1 (cons (mapcar '+ (car pt1) '(0.0 12.0)) pt1)
     pt1 (cons (mapcar '+ (car pt1) '(12.0 0.0)) pt1)
     pt1 (reverse pt1)
The next step if you dont have it pretty sure something like this
(command "_pline")
(while (= (getvar "cmdactive") 1 )
(repeat (setq x (length lst))
(command (nth (setq x (- x 1)) lst))
(command "")
IMO prefer this
'((0.0 0.0) (0.0 12.0) (12.0 12.0))
easier to manipulate by
repeat
while
mapcar
nth
foreach
vl-sort
or transpose etc.. (pls name it if missing)
LISt Process
in short LeeSP :P
