roshen_aliary Posted March 16, 2017 Share Posted March 16, 2017 Hi Everyone, I am a new Revit user and when I try to open a file, this message pop-up on my screen, can anyone please tell me what is the problem? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
tzframpton Posted March 16, 2017 Share Posted March 16, 2017 I'm assuming you are double-clicking the Revit model. This is typically seen as a huge no-no. You must always go through the Open dialog box because Revit models are usually always a Workshared file, therefore the files you receive will be a Central Model. The Open dialog has steps to open these files correctly, in which you would be bypassing when you simply double-click the file in Windows Explorer. You will have to become familiar with Worksharing, Central Models, and Local Copies: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/Revit-Collaborate/files/GUID-3896288A-0729-4C41-A67D-4FA970DF3E43-htm.html and https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2014/ENU/Revit/files/GUID-71B6BE0F-019B-45B3-B88C-F1ABBAFA66AE-htm.html -TZ Quote Link to comment Share on other sites More sharing options...
roshen_aliary Posted March 16, 2017 Author Share Posted March 16, 2017 Hi TZ, Thank you it helps me lot... :D More power! Quote Link to comment Share on other sites More sharing options...
