Results 1 to 4 of 4
Thread: Drawing co-ords
    Forum Newbie
    Facilities Mgmt
    AutoCAD 2011
    Mar 2017
    6
    Default Drawing co-ords
    Hi Guys,
    Another one for you. So I am using AutoCAD for dummies (2011) and trying to revise. On page 61 (A lap around the CAD track) I am trying to follow the instructions to draw a rectangle. At Specify first corner the instruction is to click in the drawing area at the point 32,7. When moving the cursor I can get to 32.500 but not 32,7. Any advise where I am going wrong?. If I put 32,7 in the command line it doesn't like the comma.
    Any advice much appreciated.
    Big thanks
    Franny
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Just tested the method you said failed and it worked for me. When prompted for the starting point I typed 32,7 at the command line then pressed the Enter key.
    Command: _rectang
    Specify first corner point or [Chamfer/Elevation/Fillet/Thickness/Width]: 32,7
    Wait. I know what the problem is. When prompted for the starting point you clicked in the drawing area which is not required since you are specifying the start point via your command line input.
    Senior Member
    AutoCAD 2016
    Jan 2012
    172
    Did you start the rectangle kommand before you started to click for a point?
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    There is no need to click for the starting point since the coordinates define it. Start the command, type in the coordinates and proceed from there.
  1. LISP routine to insert a block at co-ords which are dwgname dependant
    By mitre962 in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Feb 2017, 12:29 pm
  2. HOW TO? Identifying Eastings & Northings co-ords for a set out plan (AutoCAD Lt 2010)
    By GDA in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 5th Feb 2010, 05:07 pm
  3. Elevated Objects (z - co-ords)
    By Brooof in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 4th Jul 2009, 01:49 pm
  4. CAD X,Y co-ords and OS grids
    By yrmuser in forum AutoCAD Drawing Management & Output
    Last Post: 11th Feb 2008, 02:49 pm
  5. extracting Co-Ords from Blocks with Attributes
    By happyunited in forum AutoCAD Drawing Management & Output
    Last Post: 18th Jan 2007, 10:13 pm
