Help with Hatch Origin Location Program
3dwannab
Just two problems:
1.
When I hit return on the default
getkword
it doesn't run correctly.
2.
When I choose anything but the Pick Hatch Location it outputs to the commandline for each hatch entity it has been selected. How do I get rid of that. The osmode is 0.
[use current origin/Set new origin/Default to boundary extents] <Use current origin>:
[bottom Left/bottom Right/top rIght/top lEft/Center] <bottom Left>:] <bottom Left>:
;;-----------------=={ Hatch_Origin_Location.lsp }==--------------------;;
;;  Author: 3dwannab, 2017
;;  Version 0.1    -    18-03-2017
;;  Hatch Location Options:
;;  BottomLeft/BottomRight/TopRight/TopLeft/Center/Pick
(defun c:HOL nil (c:Hatch_Origin_Location))
(defun c:Hatch_Origin_Location ( / *error* os cmde pt ss ent data ans)
(defun *error* (errmsg)
	(and acDoc (vla-EndUndoMark acDoc))
	(and errmsg
		(not (wcmatch (strcase errmsg) "*CANCEL*,*EXIT*"))
		(princ (strcat "\n<< Error: " errmsg " >>"))
	(setvar 'cmdecho cmde)
	(setvar 'osmode os)
(setq acDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
(or (vla-EndUndoMark acDoc) (vla-StartUndoMark acDoc))
(setq os (getvar "osmode"))
(setq cmde (getvar "cmdecho"))
(initget "BottomLeft BottomRight TopRight TopLeft Center Pick")
(setq ans (getkword "\nChoose Hatch Origin Location ? [bottomLeft/BottomRight/TopRight/TopLeft/Center/Pick] <Pick>: "))
(cond
		(= "Pick" ans)
		(sssetfirst)
		(and (setq ent (entsel "\n Select Hatch: "))
			(setq pt (getpoint "\n New Hatch Origin:"))
			(command "._HatchEdit" ent "O" "S" pt "N")
(cond
		(/= "Pick" ans)
		(if	(setq ss (ssget "_:L" '((0 . "HATCH")))
			(setq ent (ssname ss (setq i (1- i)))
				data (entget ent)
				(cond
						(= "BottomLeft" ans)
						(command "._HatchEdit" ent "O" "D" "L" "N")(princ)
						(= "BottomRight" ans)
						(command "._HatchEdit" ent "O" "D" "R" "N")(princ)
						(= "TopRight" ans)
						(command "._HatchEdit" ent "O" "D" "I" "N")(princ)
						(= "TopLeft" ans)
						(command "._HatchEdit" ent "O" "D" "E" "N")(princ)
						(= "Center" ans)
						(command "._HatchEdit" ent "O" "D" "C" "N")(princ)
(*error* nil)
(vl-load-com)
(princ
(strcat
	"\n:: Hatch_Origin_Location.lsp | Version 0.1 | \\U+00A9 3dwannab " (menucmd "m=$(edtime,0,yyyy)") " ::"
	"\n:: Type \"HOL\" or \"Hatch_Origin_Location\" to Run ::"
I may not be following your logic fully, but I don't *think* there's anything that tells the program to default to "pick." The indicator in the prompt is just for the user. Basically you need a final COND value for ANS being nil.
dJE
dJE
Got that bit to work. By setting the variable to 'Pick' with:
(if (not ans) (setq ans "Pick"))
Can you tell me why this will output to the cmd even when the cmdecho is set to 0 in the program?
(command-s "._HatchEdit" pause "O" "D" "L" "N")
Full new code:
(defun c:Hatch_Origin_Location ( / *error* os cmde mutt pt ss ent data ans)
	(and errmsg
	(setvar 'osmode os)
	(setvar 'nomutt mutt)
(setq ex (getvar "expert"))
(setq mutt (getvar "nomutt"))
	(setvar 'cmdecho 0)
	(setvar 'osmode 0)
	(setvar 'nomutt 1)
	(initget "bottomLeft bottomRight toprIght toplEft Center Pick")
	(setq ans (getkword "\nX Brick Size (Standard=112.5 Joint=10)? [bottom Left/bottom Right/top rIght/top lEft/Center/Pick] <Pick>: "))
	(cond
		((= "Pick" ans)
			(sssetfirst)
	(cond
		((/= "Pick" ans)
					data (entget ent)
				(cond
					((=  "bottomLeft" ans)
						(command-s "._HatchEdit" ent "O" "D" "L" "N")(princ)
					((= "bottomRight" ans)
						(command-s "._HatchEdit" ent "O" "D" "R" "N")(princ)
					((= "toprIght" ans)
						(command-s "._HatchEdit" ent "O" "D" "I" "N")(princ)
					((= "toplEft" ans)
						(command-s "._HatchEdit" ent "O" "D" "E" "N")(princ)
					((= "Center" ans)
						(command-s "._HatchEdit" ent "O" "D" "C" "N")(princ)
	T
(*error* nil)
(vl-load-com)
(princ
(strcat
