x,y coordinates for a selected object
reynaldomalasaga
Good Day sir/maam..
Can someone help me!!!!!
is thier lisp program that will create text that displays the x,y
coordinates for a selected object?
thank you !!!
sir
Old one to get you started, you'll need to place Pt_Coordinates.dwg attached into a support directory along with the code.
;| Label for Point.
  PtLabel.lsp BY: TOM BEAUFORD
  ^P(or C:Label (load "PtLabel.lsp"));PtLabel
  BeaufordT@LeonCountyFL.gov
  Leon County Public Works/Engineering
(defun C:PtLabel (/ ATTDIA)
     (setq ATTDIA (getvar "ATTDIA"))
     (setvar "ATTDIA" 0)
     (command "._INSERT"
              "Pt_Coordinates"
              (getpoint "Pick Point: ")						;Insert pt
              (/ 0.1 (getvar "cannoscalevalue"))				;X Scale
;               (* (getvar "DIMTXT") (getvar "DIMSCALE"))	;X Scale (Alternate)
              ""							;Y Scale
;               ""				                	;Rotation
              (*(/(getvar "viewtwist")pi)-180)	;Rotation
              ""					        	;Easting
              ""					        	;Northing
     (setvar "ATTDIA" ATTDIA)
     (entupd (entlast))
;      (command "._DDATTE" (entlast))
Pt_Coordinates.dwg
Here's a simple one that shows the coordinates in the command line.
(defun c:XY (/ p x y)
 (while
   (setq p (getpoint "\nPick Point: "))
     (princ
       (strcat
         " X = " (rtos (car p))
         " Y = " (rtos (cadr p))
Steve
