devitg Posted March 25, 2017 Share Posted March 25, 2017 I have a: 1st xls with columns block-name att1-tag to attn-tag could be about 15 att. and columns ,at the same row with att-values. last colummn to set order number or empty , to insert the block. All data at the same row 2nd a dwt template , modelspace empty the block collection at Adoc all features by user 3rd Populate the modelsapce with blocks in a row as wide has paper space wide , and a line conecting each block with subsecuent block . It´s kind of a unifilar circuit , no branchs 4th save as phat/project.dwg Hope it is clear 5th print the dwg as pdf file 6th Open the pdf file The user will never manipulate the dwg , it is a commercial person , no ACAD skill. Hope it is clear Or at least I need to see xls-VBA to dwg from XLS , NOT acad-VBA to dwg. I´m proficient in VLISP, I want to start in this new task. Thank in advance Its a project in my mind , not materialized neither in XLS and DWT I just want to know if it is possible , and the first step on XLS VBA to ACAD . Off course the user station hold XLS, it´s ACAD VBA complements , and ACAD, Thanks in advance. The longest journey, start with the first step, No matter how short the step is. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 25, 2017 Share Posted March 25, 2017 Three ways Write a script inside excel using VBA. Or write a csv file of the data then using the commands line by line. Get the convert a csv to a list by Lee-Mac. Will make life easier. 3rd is do a direct read from excel of the cell values get a copy of Getexel.lsp it has all the functions you need. Lastly you can use a Lisp to plot the result. Me 2nd method only because I have all the bits of code to patch together. Let us know which way you want to go. Quote Link to comment Share on other sites More sharing options...
devitg Posted March 25, 2017 Author Share Posted March 25, 2017 Hi Bigal, as I state at the post The user will never manipulate the dwg , it is a commercial person , no ACAD skill. As so , ACAD , shall not be handled Or maybe do a DOS macro to open the acad session , and execute the script, it seem to be some a DOS command , I do not know how to do it . I will take a look at Getexel.lsp . Thanks Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 26, 2017 Share Posted March 26, 2017 If you can teach them the real basics open Auocad with a preferred template, do this by using a desktop icon with the correct defualt dwt, and then get them to type in the one lisp command. The rest should happen automatically. If you want to go down the custom desktop icon look at the properties of the acad icon "C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\acad.exe" /P > you can force a dwg to be opened. Pretty sure you can force a script to run also. Autocad can control excel so it could do the save as csv step. Just make a copy of your default icon. https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Startup-switches-for-AutoCAD.html Quote Link to comment Share on other sites More sharing options...
devitg Posted March 27, 2017 Author Share Posted March 27, 2017 Sad to say.The operator shall not touch Acad. I have to dig on vba from excell . Thanks for your help. Quote Link to comment Share on other sites More sharing options...
