Iterating on a dwg I got the handle of each enty in a list
(setq handle-por-codigo-list (list "4C432" "4C350" "4C2F9" "4C2F4" "4C2EF" "4C223" ))
After it, I make a enty selection set in lisp by
(setq por-codigo-ss (ssadd))
(foreach handle handle-por-codigo-list
      (setq ent-por-handle  (handent handle))
           (ssadd ent-por-handle por-codigo-ss)
Now I need to populate the variant to be send to the SelectionSet object;
input-only
The name of the selection set.
To be used at
wblock method
I created the new selectionset and add to the selectionsets collection
(setq nombre "ent-con-codigo")
(if(not (vla-item SelectionSets nombre))
   (setq nueva-ss (VLA-ADD SELECTIONSETS   NOMBRE))
   (setq nueva-ss (vla-item SelectionSets nombre))
   );end progn
Now I need to create the wblock with the NOMBRE selectionset
How I do populate the nueva-ss with all the por-codigo-ss
Off course I have the
ACAD-obj
ADOC obj
ADOC model space
and the
selectionsets collection.
Per this code
(VL-LOAD-COM)
 (SETQ ACAD-OBJ (VLAX-GET-ACAD-OBJECT)) ;_ el programa ACAD
 (SETQ ADOC (VLA-GET-ACTIVEDOCUMENT ACAD-OBJ)) ;_ el DWG que esta abierto-
 (SETQ MODEL (VLA-GET-MODELSPACE ADOC))
 (SETQ SELECTIONSETS (VLA-GET-SELECTIONSETS ADOC))
I use this defun to make the wbloc
(DEFUN &-WBLOCK/axss-nombre-arch  (AXSS
                 NOMBRE-ARCH
 (VL-CATCH-ALL-APPLY
   (FUNCTION
     (LAMBDA ()
       (IF (NOT (ZEROP (VLA-GET-COUNT AXSS)))
         (IF (NOT
               (FINDFILE
                 (SETQ NEWFILE (STRCAT (GETVAR "dwgprefix")
                                       (STRCAT (VL-FILENAME-BASE (GETVAR "dwgname")) NOMBRE-ARCH ".dwg")))))
           (VLA-WBLOCK ADOC NEWFILE AXSS)
           (ALERT (STRCAT "el :\n" "\"" NEWFILE "\"" "\ya existe."))
         (ALERT (STRCAT "No hay nada en la seleccion"))
         ) ;_ si no hay nada en la seleccion
       ) ;_ lambda
     ) ;_ function
   ) ;_ vl-catch-all-apply
Hope I explain it at all,
Thanks in advance
