Stanier Posted March 29, 2017 Posted March 29, 2017 Hi - I wish to be able to use two different styles of DDPTYPE points within the same drawing in order to have distinguishing points on different levels. When however the style is changed for one level, the system also changes that for the other despite the fact that the second level has been locked. Is there a way around this? Quote
ReMark Posted March 29, 2017 Posted March 29, 2017 (edited) I believe that the setting is global which means that even if you freeze a layer with points on it and then change the style the points will match the last style selected. Edited March 29, 2017 by ReMark Quote
RobDraw Posted March 29, 2017 Posted March 29, 2017 There is no way to have more than one point style. Use blocks instead. Quote
BIGAL Posted March 30, 2017 Posted March 30, 2017 Like RobDraw a simple lisp, method is "ssget" using "Point" & "your level" for search criteria, then insert a block at the point location. No code as I don't know what "differing levels" is. Quote
Stanier Posted March 30, 2017 Author Posted March 30, 2017 An example of what I have in mind is to have one object using a plain circle style point at size 0.05% Abs whilst a second object on the same drawing to use the same style of point but at size 0.10% Abs. Hope this helps Quote
ReMark Posted March 30, 2017 Posted March 30, 2017 Think of it this way. No two objects can occupy the same space at the same time. The SIZE of a point is set GLOBALLY just like the STYLE of a point. Take RobDraw's advice and "use blocks instead." Quote
BIGAL Posted March 31, 2017 Posted March 31, 2017 Hope this helps don't know what "differing levels" is Its a 5 minute max code job. Quote
Stanier Posted March 31, 2017 Author Posted March 31, 2017 I have adopted the Block approach but I would be interested to see the code Quote
BIGAL Posted April 1, 2017 Posted April 1, 2017 Stanier your missing the point, that is a pun "Differing levels" what is this a layer name, a height etc. ; layer example all points on Mylayer (setq ss (ssget "x" (list (cons 0 "Point")(cons 8 "mylayer")))) ; just do insert block now at the point Quote
